oil pressure fuel sandwich adapter
Old 03-19-2008 | 02:06 PM
Dkfung88's Avatar
Default oil pressure fuel sandwich adapter
so i've been looking all night, and all i found was glowshift fuel sandwich adapters but i also found that a couple of people who had this had problems with the oil filter just popping off... are there another manufacturer who makes these oil adapters that they're using and its working for you? or am i stuck with glowshift ones? i think i have to get a 3/4 one if i do plan to get it but what size oil filter should i use?
Old 03-19-2008 | 03:48 PM
Dkfung88's Avatar
anyone anyone???
Old 03-19-2008 | 06:37 PM
Dkfung88's Avatar
anyone anyone??
Old 03-19-2008 | 07:25 PM
Mr_Meaty's Avatar
Greddy makes one in a kit....but I just sold mine, sorry.
Old 03-19-2008 | 08:58 PM
Dkfung88's Avatar
have you ever used it? any problems?
Old 03-19-2008 | 09:38 PM
Mr_Meaty's Avatar
works fine...much better then the glowshift.
Old 03-19-2008 | 10:59 PM
Red_tC's Avatar
I have a glowshift one and I wouldn't recommend it because there is a small leak. A buddy of mine has one as well and he has had lots of leaking problems with it.
Old 03-19-2008 | 11:00 PM
Dkfung88's Avatar
what kind of filter did you use? just the stock oil filters that fits the tC?
Old 03-19-2008 | 11:03 PM
Mr_Meaty's Avatar
It will fit with the stock filter.
When I was using it, I had it once with the stock Toyota filter (which are actually the best ones), once with a mobil1, and once with some "JDM" filter my tuner put on there
All fit fine.
Old 03-19-2008 | 11:07 PM
Dkfung88's Avatar
thankyou thankyou
now........... how hard is it in install one? lol
oh and the oil sandwich adapter is 3/4 umf 16?
Old 03-19-2008 | 11:51 PM
Mr_Meaty's Avatar
Originally Posted by Dkfung88
thankyou thankyou
not sure what 3/4 umf 16 is, but it's really easy to install.
When you go to change your oil, you take off yoru old filter.
Then, you screw the adapter in using the center bolt that is supplied with the kit.
This brings the bolt for the oil filter down further to compensate for the thickness of the adapter (I beleive this is where the glowshift has a problem) Tighten down the bolt.
Then you simply screw your oil filter into teh new extended bolt.
obviously you would pick which fitting to undo for whatever gauges or whatnot you are connecting to the adapter.
Old 03-20-2008 | 01:49 AM
yamaha16bw's Avatar
I use the greddy one shown and its has worked fine for over a year.
Old 03-20-2008 | 01:50 AM
Dkfung88's Avatar
if its not a problem.. can you take some pics on how your wires are hooked up? including the gauge
Old 03-20-2008 | 07:24 PM
JL56TC's Avatar
I hve a glowshift and I put some hi temp gasket maker beween the 2 rubber seals. It has never leaked... however If you dont teflon tape evruthing I could see how there would be a problem. The other thing I would suggest is trying to find a thermal oil sandwich plate b/c it will close if it gets too cold. It may take some inovation but you gotta find out what works the best for you.
Old 03-22-2008 | 04:49 PM
SoccerBoy_AP's Avatar
/ditto
Must Use Teflon!!!
I have a glowshift one and running w/o leak
Old 04-21-2008 | 12:12 AM
rockbrawler884's Avatar
I was running a GlowShift sandwich adapter for 1 year under boost applications... ZERO leaks... use Teflon!
my06tc
06-25-2015 01:18 AM
yhwhdesign
03-07-2015 03:01 AM
k1114
03-06-2015 04:43 PM
cid_mcdp
01-05-2015 03:45 PM
eric_m
79
03-17-2013 01:21 AM
