Oil Pressure Gauge Install Question
Hey everyone, i bought an Autometer Electric Oil Pressure Gauge....i cant figure out where to hook the sending unit at. Can anyone tell me how to install it or, could someone show me where i might find a set of directions??
Everyones help is greatly appriciated!!!
Thanks
Thanks
generally the instructions come with the unit, and if you do a search on here, when i was working on mine, i had found a thread that talked about it. but in the end, if you go to autometer.com or google autometer electric oil pressure gauge, you should be able to find the main site with the instructions. hope that helps
right next to the block there is an engine oil pressure thing for the stock ecu...pull thatout and put it there then find a bunch of fittings at lowes or home depot in the air tools section...they work, use thread sealent. don't put the fittings in until you put hte oil feed line in.
ok, ill pick up a T fitting and find the stock dummy sensor...put the T in where the dummy was and hook the dummy and the sending unit up to the T right?
Thanks everybody 4 the help
I think i found the stock dummy sensor...is it near the top of the motor, on the drivers side, near the front of the car??
I feel so stupid for asking, but can someone give me a pic showing me where its at?
Thanks
Thanks
my06tc
06-25-2015 12:18 AM
wiltonhall
01-28-2015 03:46 PM
mattjk
121
12-22-2004 10:49 AM
