View Poll Results: Which EMS
Voters: 22. You may not vote on this poll
OK, The Piggyback VS Standalone thread!!
Originally Posted by deathbyc4
your poll is flawed, you forgot the dezod ems!
There is no proof it even works.
Here is the Dyno sheet for you-
272 WHP
250 WTQ
And here is a quick vid for you all it says 7lbs but I am actually running 8.5lbs.
http://www.youtube.com/watch?v=6kC7vZ14LEg
Who said anything about the AEM EMS. That's not what he was talking about. He said the OP forgot to add the Dezod EMS, their new one they have not tested out yet. Not the AEM unit. As you can see, the AEM EMS is included in the Poll.
I would sugest the e-manage Ultimate. It has more features that you will ever use really. @ step launch control, rev limiter increase, control of boost sylinoid... many people don't even know it has those functions and turn to a stand-alone. A stand-alone also will take much more time to tune. The factory toyota computer is tricky indeed, but all you have to do is disconnect the front o2 sensor plug (takes 30 seconds) and reset the computer for zero fuel trim before the car is tuned... and you will never have issues with the toyota computer changing your tune. When it comes time for emissions, just plug the 02 sensor back up
I guess I have no idea what your talking about cause I am running the Dezod EMS...
https://www.scionlife.com/forums/vie...854&highlight=
By the way , how is drivability when you try to throw the car to open loop by removing the O2 sensor?
I did that, but I always had a problem with the driveability down low because this was during the sporadic winter (one day it would be 20 degrees and then the next day it would be 65 degrees out). So, I had to always have the laptop plugged in to regulate to keep the car at 14.7-15.2 A/F ratio.
272 WHP
250 WTQ
Originally Posted by ElevationTC
so there is no way to get around the weather thing? or can you adjust fuel trim with a AIT sensor? so that when the computer seen cold temps it could increase fuel output?
throttle
coolant temp
baro pressure
EGT
Battery offset
Air temp
Fuel Offset
Boost
And a user definable one as well
No comparison. Hydra EMS will work best drive best and make awesome power (helps you get the most of what you have). I'd say the only thing holding you back is that tiny 0.63 AR on the exhaust housing. This is not a 1.8 liter!
The conversation was about the Piggy Backs reactions with unplugging the 02 sensor.
Of course the Standalones are going to be different in that aspect.
If money isnt a factor then a satandalone is definately the way to go, but like I said... it takes A LOT of tuning to make it have full control over your car compared to what the factory ecu does because the parameters for the factory sensors are perfect( to begin with)... it is something of a blank slate to begin with when installing a standalone.
1 a/r seems quite big for our motor, 0.82 might be as big as you wanna go so you dont have to worry about too much lag..
Well, I guess that all depends on your mods. If your talking about on the street, simply brake boost it.
Talking about from a dig....well, as long as you have 2 step you don't have to worry about off the line either.
Of course there is no way I would go 1 A/R if it's not Dual BB.
