ok so tunning...
Originally Posted by purplenitroustc
you are aware of your intake temps with no intercooler right.. also those cast pistons in your camry block
not to mention the lack of fuel acting also as a cooling agent
It's fine on 5 PSI. You can run as much as 6 - 7 PSI without management. Puts down around 220-230whp depending on the turbo. And it's not called a Camry block. It's a 2az-fe.
There is no point in running 3.5 PSI. That's worthless.
TO THE OP AND EVERYONE ELSE.
DO NOT BUY ANYTHING FROM PURPLENITROUSTC.
EVER NOTICE HOW HE SEEMS TO HAVE EVERYTHING FOR SALE THAT EVERYONE IS LOOKING FOR...?
https://www.scionlife.com/forums/vie...2817&start=380
Originally Posted by jetlounge
megasquirt
I think you should get something that has already been proven, as the others have stated.
It'll definitely save you the hassle. I'd say emanage blue or aem fic is your best bet.
5-7psi you shouldn't have a problem boosting with not management. Don't forget to use premium ^^
A WG spring rated under 5-7psi, is a waste of money, lol.
The minute you're boosting, your going to want to boost more. Its the sad fate of all who boost, hahaha.
haha no back when i was boosted 6psi was enough because i KNEW anything more was asking for trouble, i mean my turbo pushed out way more cfm than a 16g so i know i made atleast 240whp easily
A big evo III 16G pushes 220-230whp at 6 PSI. I dynoed it at 7 PSI and put down 250whp/260wtq.
ahh nice so i made around 240-250=] right travis?
Should be ball park, depending on exhaust setup and what-not. You were running without an intercooler though right? If so, numbers are going to be lower than that.
yea no intercooler=[ fail! haha i had stock axel back with straight pipe midpipe i did this for the sleeper sound then when someone laughed or got big i gave them wastegate
Just a ball park guess, with that setup I would estimate 200-220whp.
