PCM processor fault
Old 02-02-2009 | 08:44 PM
gingles's Avatar
Default PCM processor fault
not sure if this is the right spot for this topic or not.....i read my codes today and came across this one.....i researched and it seems to have something to do with the secondary o2 alot of times.....well...im not running any o2's so i can tune partial throttle......its raining today and was thinking maybe some water got into the connector and maybe crossed the wires or something....not to sure but was wanting some more input...im also running a blow thru maf setup...not sure if that as anything to do with it but hey every little bit of info helps.
Old 02-03-2009 | 03:12 PM
toyota_scion_tc's Avatar
I had that code when I used o2 sim on the secondary o2 sensor. Could be map or you o2 sensor plugs grounding out on something or just a bad sensor i.e. maf.
Aroxguns
03-20-2015 11:06 AM
spikeymike78
09-25-2005 01:09 AM
nycazn79
04-18-2005 07:23 AM
Nathant888
30
09-03-2004 07:49 PM
whippets2
30
05-26-2004 03:35 AM
