PCV on 2AZ-FE
PCV on 2AZ-FE
So since the tc motor is technically supposed to be N/A that means when you make it forced induction, the rear pcv gets shut when your boosting .... would this cause the crank case not get vented properly?
from experience, ditch the pcv and route it to a catch can along with the other hole in the valve cover then route a line from the intake of the turbo to the catch can or just to atmosphere. if your pcv fails somehow and u get boost in your head, your turbo is toast.
I think there should be an equilibrium between the rear pcv and the front breather. If the fitting you put on the valve cover is much bigger than the little hole in the fitting in the front breather, then all the crank pressure will go out the larger hole where the rear pcv used to be, causing an excessive amount of oil build-up in the catch can. For example if you unscrew the oil cap, you get super oily air coming out while the front beather and rear breather are now defunct.
1.So maybe we should leave the rear pcv as is so it still works on idle.
2.Make a fitting in the oil cap the same size as the little hole in the front breather.
dude its an easy fix run the front breather to the intake side..=...in boost ur turbho will be sucking out at full force so there wont be pressure in crank case unless the rear pcv fails and lets boost in....
if u wanna be worry free the just run both breathers into a catch can and then the catch can to the intake... drain the catch can every 2 weeks back into the motor
PS. I think thats why all the s/c guys are blowing thier seals on the blower. The s/c seal is much weaker than a turbo seal and that extra pressure just blows by.
This is probably what we will do. The problem is that rear pcv if you leave it in, sure it closes when your in boost, but thats the problem you loose that extra vent for crank pressure. In an na car that pcv never really closes because you never build pressure in the manifold, your either in vacuum or at atmospheric. Thats why we are thinking we are getting smoke when letting off the gas, only when letting off the gas after being in boost. And if you look on youtube, most other turbo tc's do it also. Routing both of those to a catch can and then routing catch can to intake before turbo would be ideal i think. We shall see.
mikeytomas
08-06-2015 08:54 PM
30
05-29-2009 08:10 PM
