Pictures and video of the Turbonetics Scion Tc Kit!!!
Old 02-06-2006, 02:22 PM
  #181
MIAPLAYA's Avatar
Originally Posted by jonathanlepierson
i bought this kit but i want to get a pre tapped pan from zpi, so which size oil line option do i need to pick? i believe they are 8, 9 or 10 so which one of these...if you know? Unless tapping the pan isnt as hard as i think it is... is welding required?
Tapping the pan is easy. Turbonetics even provides the tap you need. There is no welding required...
MIAPLAYA is offline
Old 02-06-2006, 02:28 PM
  #182
mattssi's Avatar
On my lex, we didn't even need to remove the pan.... drilled the hole, used the tap, ran some oil through to remove any possible shavings, then put the fitting in. pretty easy
mattssi is offline
Old 02-06-2006, 02:40 PM
  #183
MIAPLAYA's Avatar
^^^ Absolutely correct. Same thing on my Z and my buddies G.
MIAPLAYA is offline
Old 02-06-2006, 10:06 PM
  #184
zer0's Avatar
videos?
zer0 is offline
Old 02-06-2006, 10:07 PM
  #185
MIAPLAYA's Avatar
Originally Posted by zer0
videos?
They will be re-hosted by noon tomorrow. I am uploading them to a site tonight...
MIAPLAYA is offline
Old 02-07-2006, 12:35 AM
  #186
jonathanlepierson's Avatar
thanks for the info guys...my friend told me about the method you guys used... but what are the odds your going to get all possible shavings out?
jonathanlepierson is offline
Old 02-07-2006, 12:37 AM
  #187
MIAPLAYA's Avatar
The odds are very good. If you use some grease on the tap while tapping the threads it will hld onto most of the shavings..Everything else can be blown out with compressed air..
MIAPLAYA is offline
Old 02-07-2006, 01:04 AM
  #188
would oil work as good as highpressure air ...if not whats the method of blowing the stuff out.. i can only think of sticking the blowing end down where you pour the oil in
Old 02-07-2006, 01:09 AM
  #189
i think it was you "miaplaya" that said the uni chip would keep the "cel" off but what if your having a problem with the o2 sensor on the s pipe and its causing my cel to come on?
Old 02-07-2006, 01:16 AM
  #190
MIAPLAYA's Avatar
The Unichip will not throw a CEL for the lack of a cat if thats what you are asking. As for the oil I think maybe we are mis-understanding each other. When you drill and tap the oil return you drop the lower oil pan and drill and tap it with some grease to collect most of the shavings. Then you blow out the hole with air. Install the fitting and then re-install the lower pan
MIAPLAYA is offline
Old 02-07-2006, 01:34 AM
  #191
we are mis-understanding miaplaya...i'v heard people say wars start over such such situations as this
Old 02-07-2006, 01:36 AM
  #192
MIAPLAYA's Avatar
No war starting here. When I have the install instructions I'll post them and you'll see what I mean.
MIAPLAYA is offline
Old 02-07-2006, 05:09 AM
  #193
MIAPLAYA's Avatar
All videos including dyno videos now hosted here:
http://www.petn.us/scion/
Thanks to Jamia for hosting them!!
MIAPLAYA is offline
Old 02-07-2006, 05:37 AM
  #194
Jamia's Avatar
Glad to help man.
Now get to downloading these videos.
Jamia is offline
Old 02-07-2006, 04:54 PM
  #195
MIAPLAYA's Avatar
Glad to help man.
Much appreciated!!
MIAPLAYA is offline
Old 02-07-2006, 06:40 PM
  #196
zer0's Avatar
How audible is the BOV, videos dont do justice. I want people to know when I rev behind them I mean business...
zer0 is offline
Old 02-07-2006, 10:15 PM
  #197
MIAPLAYA's Avatar
its audible within a 1 car range if you rev it hard...
MIAPLAYA is offline
Old 02-08-2006, 01:54 AM
  #198
i picked up my turbonetics kit from fedex today.... SO back on subject miaplaya.... the kit has a punch so no drilling required....then the instructions says exactly what you told me"miaplaya". ...grease the tap so it collects the shavings.....for someone that calls himself a noob"miaplaya" you know quite a bit of good info....but you might have been refering to promoting....but who cares the kits beautifull prob more beatifull than the s you be playing...the kit is exact as seen on turbonetics...so no douts there...props to turbokits.com
Old 02-08-2006, 02:01 AM
  #199
mattssi's Avatar
Can you take a pic of some components and misc items included? any pix of instructions, etc would be awesome too. Thanks!
mattssi is offline
Old 02-08-2006, 02:09 AM
  #200
my kits a few miles away at the moment"at storage." so maybe tomarrow or maybe miaplaya will have them up by then...but since it took so long to get the videos up it might be a week or to..just kidding... in the meen time i think you should know that the kits installation process is simple but yet correct....and everything needed to install the kit is coming along with the turbo kit and its all in the same box...
Quick Reply: Pictures and video of the Turbonetics Scion Tc Kit!!!
