POP! Since overdrive pully and bypass valve install.
I've noticed a couple times since my NST overdrive pully and bosch 110 bypass valve install, When I stomp on the gas max psi shifting from 1st into 2nd there's a POP! sound. Maybe backfire. Anyone know about this?
After some time with the problem, the conclusion is that it's my rev limiter....some how i need to shift a little sooner, it's automatic....I'll search unless anyone wants to jump in.
Originally Posted by aen
it's just backfire don't worry about it, just the extra pressure that's built up
Yea with trd tune your prob running rich, not running meth are you? I run meth inject on my turbo set and when i let off after a long pull i get a backfire every now and then do it not immediately cutting of the methanol inject
