problem...
Originally Posted by Simplyscion
I doubt its a bad coil pack but see if anyone of your friends can swap coil packs out with you to see if its a problem. What year is your car? If its an 07 I can help you out here at the dealership with a leftover car we have just to test it out to see if thats the issue(actually they should be the same from 05-08 but who knows). Also, you should be running lean at idle...it should be stoich @ 14.7-15.xx a/f ratio...unless its something crazy off the charts thats not a problem if its in that range
Team No Limitz
im working tommorow the only thing is I cant really let you drive away with them, youd hafta drive the car here to do the swap or they would kill me lol. Im not gonna get in trouble for something like that, but like I said, if you could drive out here in the tC then id be more than happy to take a look at it for you and help diagnose it. Im working 9-3 so if you want call the dealership up and ask for vito...number is 631-724-3300
wow simplyscion, i really appreciate that, if im not working tommorow or if i get off before 3:00 ill get in touch with you. last thing i want to do is get you in trouble at your job for trying to help me lol hopefully ill be able to meet up with you tommorow then. thanks again.
alright i found why i was gettting the ignition coil code.....didnthave the ignition wires plugged into it all the way...i know stupid me. anyways, after fixing that the car idled much nicer, still tho it idled around 17-18 :-\ could be a possible exhaust leak i guess i smelt exhaust from the engine bay but dont know how to be sure.
BlueScionXB
05-08-2004 01:43 PM
