PSI and MAF - Clamp? What is it?
![10 Year Member](https://staticssl.ibsrv.net/autocomm/Content/ScionLife/SL_ten_year_badge.png)
![5 Year Member](https://www.scionlife.com/forums/images/misc/SL_five_year_badge.png)
So I am not too good with tuning. Actually, not good at all. I have read about "clamping" the MAF after a certain PSI or something like that. Can someone give me a better understanding of how that works or what it does. Also, the main question is how much PSI can the MAF handle if you want to just use the MAF to tune the vehicle? Thanks
So lets say I wasnt using a emanage or fic or anything like that. Lets use the apexi for example.....Could you run 10, 11, 12 psi with the MAF or would the MAF throw codes and not work????? With understanding that the apexi would not pull timing obv.
How much airflow the stock MAFS can read depends on the diameter of the MAF tube. A larger tube will allow the MAFS to read more airflow but you'll need at least an FIC or Greddy Ultimate to tune for such a change. The FIC has a MAF map that allows you to adjust the MAF signal +/- and clamp it.
Hydryman
02-23-2016 03:35 PM
