PTUNING: Competition 2AZ-FE Short Block (Spec A)
#41
i wanted this motor and still do i had talked with you a while ago about it i really wanted to get things moving had i not of started my build while waiting i would have went this route and a good builder is whats its all about most places will assemble a motor for a fair price pay it my shop charges 400 for a short block 1000 for full block thats new valves and all the goodies machining block for sleves and making all mods to fit new componets 400 the thing is motor builds cost money so spend it make it worth it
#42
Guest
Posts: n/a
MrC
#46
Question. Im interested in this, but I wont have the money to get the turbo set up until some time after I do the engine. Is it alright to run this without getting a turbo off the bat? Would it not run properly or will it be great by itself?
#48
Originally Posted by java09
^^ ARE EEE AHH DEE, READ!
3 weeks.
3 weeks.
#50
Originally Posted by Scott8
HOLY CRAP!!!!
so this means that:
i send you my short block
do your little magic
send me back my short block
install and tune
OR
you send me a ready to install short block with all the stuff installed, its just a matter of swapping the new one with my stock one
send you my old block
refund the core charge
tune and enjoy
? am i missing something ?
#51
Guest
Posts: n/a
HOLY CRAP!!!!
so this means that:
install and tune
OR
tune and enjoy
Option 1: Build your block, preserving engine VIN#
- No core charge
- You can strip down your motor
- Send us the short block, crank, main caps, factory main studs
- We build and blue-print the block, install the rods, pistons, gap the rings, clearance the bearings, torque everything to spec.
- We send you back your short block
- You put the motor together, cylinder head, timing chain, oil pump, water pump, sensors, etc.
- install the motor
- tune and enjoy
Option 2: Build one of our block, different engine VIN#
- Core charge up front
- We send you back our short block
- You swap all the components & accessories from your old motor to the new block.
- install the motor
- Send us your short block, crank, main caps, factory main studs
- When we received your short block, we will inspect it to make sure it's a rebuildable core, i.e. no cracks, holes in block, spun main bearing, or any other types of damage that makes the block unusable. We then refund you the core charge.
- tune and enjoy
Option 3: This is the expensive option of you don't feel like you will be able to assemble the complete motor youself. You can ship us the complete motor and we can strip it down, build it, reassemble everthing and send it back to you. All you will need to do is connect all the sensors and wiring harness, fuel rail, etc. and you're ready to go.
MrC
#53
I'm all about Option 3. I want to take it out, send it, get it back, and drop in and tune. Then again, I just might bring you the whole car so you can do it all there with the tune.
#54
#56
#58
- No core charge
- install the motor
- tune and enjoy
- install the motor
- tune and enjoy
- No core charge
- install the motor
- tune and enjoy
- install the motor
- tune and enjoy
-Steal Javas credit card
-Pay for Option 3
-Use newly built super fast car to escape Java
-Post pics on SL and laugh at Java
