PTUNING: Competition 3" T304SS Exhaust (now-PREORDER)
#62
Guest
Posts: n/a
Prototype Exhaust Pictures
We'll be announcing the price and availability tomorrow. Below are pictures of the PROTOTYPE system. Keep in mind the production unit will include the following features:
S-back 3" exhaust system features
- Full 3" T304SS mandrel-bent tubing
- T304SS exhaust hangers
- T304SS lightweight V-Band connections (instead of 2-bolt flanges)
Eliminates exhaust gaskets and thereby any potential gasket leaks
- Fully polished exhaust system with mirror-polished exhaust tip
- Centralized-muffler design for better weight distribution and stealthy appearance
- T304SS Adapter for connecting to factory or other aftermarket s-pipe
- T304SS easily-accessible rear O2 bung for dyno tuning (Installed on exhaust rear section)
Eliminates faulty lean-AFR readings when trying to dyno a vehicle with a 3" exhaust using a tailpipe sniffer (To be used by your dyno tuner)
- All components are carefully designed with maximum ground clearance in mind
- We've added an extra horizontal hanger & mounting bracket for the rear exhaust section to eliminate excessive exhaust tip movement during hard cornerning (we discovered this problem during our timeattack sessions - burnt rear valance). Most aftermarket tC exhaust systems only utilize one rear exhaust hanger making it difficult to control the side to side movement of the rear section during cornering.
Turbo-back 3" exhaust system features
- Includes all features in the S-back exhaust system
- Full 3" T304SS 2-piece s-pipe
- T304SS dual O2 bungs (Installed on S-pipe)
First O2 bung for factory secondary O2 sensor
Second O2 bung for use with aftermarket wideband O2 sensor
- Exhaust Systems will be made in the USA
MrC
MrC
#66
I have a full exhaust from the header back, but the shop I took it to didn't do too good of a job, and I'm not too happy with the sound.
I wouldn't mind a similar setup, but 2.5" for the supercharger setup. I also would like something that sounds good, because right now, I don't like to accelerate hard because of the way my car currently sounds. Rattles like crazy, worse when it rains, and I have a pretty big cut on the heat shield because the hi-flow cat keeps rubbing it. They also didn't put the exaust hangers back on to connect to the Megan header.
One of the fixes the shop charged me for was heat wrap around the tail pipe so it deadens the sound of the rear section hitting the heat shield.
#68
drum roll for price......
also, will you be providing o2 bung bolts? i wouldnt need a second bung since my wideband is on the downpipe. and do you provide a donut gasket for the downpipe to s-pipe? probably not but it doesnt hurt to ask. I know that my stock donut gasket does not fit my downpipe and i had to custom order one, still doesnt fit right.
#71
Guest
Posts: n/a
Originally Posted by recliner15
Bolts right up to the greddy kit? Also any possibility of getting the downpipe and s-pipe seperately?
We will be selling the 3" s-pipe separately but it was designed to integrate into our 3" exhaust system. Of course if you are already have a custom 3" exhaust, you can easily cut the rear flange and weld on whatever flange you will need to connect to your custom 3" exhaust.
MrC
#72
Guest
Posts: n/a
MrC
#73
MrC
#74
Guest
Posts: n/a
MrC
Click here for pricing on our exhaust system
MrC
#75
yea finding a suitable donut gasket is...well like finding a donut amongst a dozen cops. Post up some pics of the exhaust with the v-band adaptors since the ones you posted were the mock-up. No rush, just would like a better idea of what ill be ordering in a month or three.
BloxRacing
Regional - Pacific Mid
04-17-2015 10:17 PM
BrokenTC2
01-27-2015 03:32 AM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
