PTUNING: New 625cc injectors for the Scion tC
Old 10-11-2007 | 09:30 PM
Guest
Guest
Posts: n/a
Default PTUNING: New 625cc injectors for the Scion tC
PTUNING worked with FIC to develop these injectors for those looking to extract more power out of your Greddy turbo kit or any turbo kits for the 2AZ-FE motor that came with 440cc or 550cc injectors. The injectors that comes with the Greddy turbo kit is rated at 440cc at 43.5psi of fuel pressure. These injectors are rated at 625cc @ 43.5psi, given you 42% more flow rate over the 440cc and 14% more than the 550cc injectors. Our injectors have a broader spray pattern than the competitors, resulting in better fuel atomization and a smoother idle.
These injectors are a direct replacement for the RC injectors, they both use the same Delphi-style injector plugs. If you're upgrading your stock injectors to these 625cc injectors, you will need to buy the Delphi Fuel Injector Connector Plug (Part# PTFICDelphiPlug)
Note: These are brand new injectors. They are not modified used stock injectors that are made to flow at a higher rate.
For pricing and availability, please refer to post:
https://www.scionlife.com/forums/vie...913934#2913934
These injectors were used in our Redline Time Attack turbo tC with excellent result:
http://www.ptuning.com/html/redline_timeattack.cfm
For technical questions, please contact us.
Old 10-15-2007 | 04:21 PM
Guest
Guest
Posts: n/a
A few customers have PM us to see if "a retune is required after installing these 625cc injectors? The answer is YES. As with any upgraded injectors, it is necessary that you retune your EMS to accomodate the new injectors.
Old 03-25-2008 | 08:25 PM
XD40tC's Avatar
BUMP! Getting these for the xB2!
Old 03-25-2008 | 08:52 PM
Guest
Guest
Posts: n/a
FYI, our injectors offer a much broader spray pattern for better fuel atomization of the fuel/air mixture when compared to the RC/Lucas injectors.
MrC
Old 03-25-2008 | 09:43 PM
XD40tC's Avatar
Oooh nice! You guys should make nitrous nozzles
Old 03-25-2008 | 10:18 PM
Mr_Meaty's Avatar
Nice...but 625? why not 650? or 666
Old 03-25-2008 | 10:55 PM
Guest
Guest
Posts: n/a
Injectors are usually sized by lb/hr. That is 40lb, 50lb,60lb,70lb, etc. 625cc injectors are 60lb/hr injector. We do also offer 70lb/hr (750cc) high-impedance/saturated injectors if needed. Beyond that we will be offering low-impedence peak/hold injectors which will require an injector driver box or resistor box (850cc to 1600cc).
MrC
Old 03-25-2008 | 11:18 PM
PlayinWithFire's Avatar
EDIT ignore me...
Old 03-25-2008 | 11:25 PM
Mr_Meaty's Avatar
ah...just wondering cause I have 650cc RC injectors in mine.
Old 03-25-2008 | 11:38 PM
Guest
Guest
Posts: n/a
depending how you round it off 625, 630, 650 are pretty much the same flow rating (60# injectors).
Old 03-26-2008 | 09:31 AM
Guru's Avatar
MrC
Or a Hydra. Hydra EMS can drive low or high impedence injectors with just the click of a box in the software.
jdstC1
01-13-2015 05:45 AM
JM Auto Racing
12-19-2014 07:36 PM
hotroddelux
12-04-2014 12:33 AM
ilikepinktacos
11-30-2014 12:32 AM
foxSCION
13
12-03-2003 06:40 AM
Quick Reply: PTUNING: New 625cc injectors for the Scion tC
