PTUNING: PnP Water/Methanol Injection Kit now available!
Originally Posted by SoFloTC
whats the difference between this and a generic AEM kit that goes for 450
The single most difficult part to PROPERLY install is the water pump. The reason for this is that it uses awkward tiny 4mm bolts for mounting (not even included in the regular AEM Kit). We tried many iterations of pump mounting locations before settling on the final location. Our pump location keeps the pump low enough to making pump- priming a non issue and keeps the length of plastic water lines short (the shorter the lines the fewer the possible points for failure). Btw, the pump will clear VRD fog lights too. Our WMI pump features a weather-pack style connector that plugs directly into the main PnP harness.
Secondly, if you were to get the AEM kit with one-gallon reservoir, you cannot simply remove the low-water level sensor to use with your factory reservoir. That is because the sensor is glued to the AEM reservoir. Our kit uses a factory reservoir friendly water level sensor and it's exact placement has been tested for you. Our level sensor also features a weather-pack style connector that plugs directly into the main PnP harness.
The main unit features a laser etched (PTUNING logo) bracket that mounts to the brake master cylinder reservoir to allow for easy adjustments to the WMI controller and also prevents the need to run long lengths of vacuum tubing into the cabin (in cases where the controller in mounted inside the car). The power connections to our failsafe relay and WMI controller are pre-fused and allow for a direct plug-in to the factory engine fuse box (no ugly and unreliable connections needed to the positive terminal of the battery). Even the ground wire has a pre-attached connector to allow for a direct bolt-on to one of the existing factory ground clusters for ease of installation and perfect grounding point.
The standard AEM kit features a failsafe output on the WMI controller, but unless you know what to do with it, no one ever bothers to even make a connection to it. What we've done is integrated a relay (mounts using a factory bolt lacation) to allow you to use make use of this very useful controller output.
The standard kit has no rocker switches or anything to activate the WMI controller. Our kit features a pre-wired PnP (fits factory switch panel) rocker switch to allow for activation of the WMI control and EBC solenoid. We've even included another pre-wired tap-a-fuse connection to provide a switched power source, without having to make a messy t-tap connection into the factory wiring cluster.
Lastly, the standard AEM kit will need a LOT of wiring to make it all work on the tC. We've extended the wires going from the WMI controller to the pump, level sensor, and even LED. What you don't see are the large number of wires going back and forth through all the branches of the pre-assembled wiring loom.
I can assure you that even after we created the schematics for the PnP wiring loom, it's actual assembly still takes a LOT, and I mean a LOT of time to put together. Everything from taping to soldering to crimping to heat shriinking is involved in the assembly process. Unfortunately, it's not as easy as slipping Boomslang a bill and asking them to ship us back a completed PnP harness. We have to make these things in-house.
Anyhow, sorry everyone for the long response. I guess I just spent way too much time on this WMI project and wanted to give you guys all the drity little details.
- Toan
Toan -- Since I have the Air/Brake ducts in my front bumper, I actually had to remove the factory fluid tank. How much of a hassle would it be for your PnP WMI kit to use the AEM tank?
Btw, your car looks to be coming along nicely. Way to step up and represent. We're looking forward to seeing a lot more tC's at the TA events this season.
- Toan
- Toan
Awesome! Thanks Toan. Can't wait to get up there to see the facility.
I got i question...
This where to get the methanol for the kit to refill it ?
also when factory windown washer tank is used will it still work for the windows ?
i'm jsut not sure how this works but thinking about getting this kit to help my dezod intercooler run higher boost.
Originally Posted by RusWolf
I got i question...
We use this same WMI kit on our 500+WHP, 93 pump gas, Time Attack tC. WMI can certainly help to improve charge density and reduce the onset of detonation on any forced induction car. WMI allows you to safely run a little more timing and quite a bit more boost, ultimately resulting in more power.
- Toan
Ok cool...
for example when someone runs out of WM is it still safe to drive the car in boost without it ?
Some people use the WM kit for added cooling and safety, but still maintain a conservative tune. Others run a very aggressive tune since it's similar to running racing fuel. If you have an aggressive tune that takes advantage of the WM injection, then running out of fluid could be bad.
The kit comes with a light that lets you know when injection is engaged and if there are any issues or you're low on fluid. You can also use the controller to send a signal to the engine management to retard timing or default to a safe tune (kind of like limp mode) when the WM controller senses a problem or low fluid.
http://www.aempower.com/ViewCategory...CategoryID=120
OTHER COOL STUFF
You don’t have to worry whether AEM has your application because the Water / Methanol Injection Kit is designed to be universal for practically any vehicle. It includes everything you need to adapt it to your steed. Critical safety features are integrated into the system to virtually eliminate any chance of failure, including an integral fluid level sensor in the reservoir, a dash light to warn of low fluid level or error codes (including short circuits, battery voltage and more), and an additional output to either decrease ignition timing or boost if the system detects low fluid levels or a system error.
Originally Posted by b52hDUNN
What kind of results did you get with the kit on the supercharged tc?
I was able to get 237whp on Ptuning's dyno with the 12psi pulley, Ptuning exhaust, and GReddy Ultimate. It's still a very conservative tune, mainly to prevent going through gallons of methanol during daily driving. It's currently set up to start injecting at 6psi. I'm using Snow Performance's Boost Juice, and haven't gone through one gallon since the kit was installed.
After I get Gompka's s/c shaft installed, I'd like to get back on their dyno for a more aggressive tune. I'd like to have more power for daily driving and have a second map for track use.
NonStopTuning
06-29-2015 07:42 PM
my06tc
06-25-2015 12:18 AM
umnitza
12-01-2014 06:26 PM
