Putting together my own turbo kit under $2000
Stock clutch will hold 4 psi no problems - theres a local tc Ive worked on that just started having his slip at 9 psi on a 60 trim t3/t4 on an older TurboToyotas kit. Id highly recommend just getting a FIC and doing it right from the beginning. Just save up a lil bit longer.
As I stated before I won't keep it this way unless I can get my a/f ratio to stay somewhat decent. If my a/f ratio isn't cutting it for me I'll hold off until Ican buy the fic. I have a 96 s10 I can drive around if I need to have my car down for a little bit. My brother-in-law has run a .60 trim on his klze-mx6 for the last 4 years on 9 psi with no tune and just watching his a/f, with no problems at all. His clutch is what gave out a 8 psi.
Just trying to get all the feedback I can
Yeah I just need to search a little more for a decent priced used one
Maybe, but your AFR will be on the lean side and really lean out if you max the inj's. I'd rather risk losing a clutch than an engine.
Overall you could do this with the amount you stated previously but always have funds ready for when something unexpected occurs.
You can find an FIC or Eman for low price it just takes time and luck.
The stock ECu will compensate for the changes in AFR by adjusting the fuel trims and try to keep everything in factory parameters. But of course you know a proper tune is needed to take full advantage of your setup.
Like others have said the stock clutch can take about 9psi or 300 hp before it gets mad and quits playing. But with 440cc's and such low boost you won't have a problem with it.
Keep us updated on your progression.
Well to your question on MAF placement it depends on your setup.
-Blow-thru or Conventional sensor on the intake pipe running to the Compressor housing.
Blow-thru offers more precise readings,better spool,proper use of BOV dumping to atmosphere,less lag or restriction. With this it goes Throttle body,MAF,BOV
-Conventional setup offers safer operation of turbo meaning the compressor is not exposed to an open engine bay. Recirculating the BOV back into the intake stream for stealth operation but can cause fluctuations and cause false readings or in some cases the car stalls out. This is MAF sensor on the intake pipe with a air filter and then BOV on the pipe running to the Throttle body.
Overall for better performance and drivability. Blow-thru is the way
Whew this is long winded hope we helped you out.
Definitely! So far you guys have been most helpful
anyone run the competition stage 2 clutch kit? Any thoughts on puck style clutches, I was told they have a tendency to chatter. It seems as though every clutch that looks like it's worth a damn is a puck style.
Wow I just finished reading thru this thread and just wow..... okay first off NEVER NEVER NEVER run a car untuned its just common freaking sense. A the first thing is please don't even think about going down the road of getting by with an ebay turbo kit for your tC, its only going to cause an a$$ ton of problems. B without any sort of Engine Management at all dont even think about installing a turbo kit. C I read up above that someone stated 440cc injectors? Not even close enough to being able to handle the duty cycles and latency that is required during boost at WOT. And finally D how do I know all of this? Do I really know what im talking about or am I just blowing smoke up all of your @$$'s? Well I had a 2008 tC that went through 4 different turbo kits/set ups, 3 different companies and worked very closely with Paul and Don at Dezod and Jason at Treadstone. I learned over the years to tune and to fabricate, because I worked so closely with Paul and Jason in learning everything I could I now have my own Dyno Shop. So in hind sight to the OP if you cant afford the kit that has been tested and known to work that is a complete install and pretune map to have you set to drive to a tuner and then get tuned, then you shouldnt be even thinking about turbo at all. And a properly tuned tC at 10 psi will eat your stock clutch alive if you want something with OEM street-ablility by an ACT HDSS or something similar that is a Single Disc Sprung set up. Any pucked clutch is going to have chatter and a harsh engagement no matter what. If you are looking for a good price on a used Turbo kit tho let me know I do have 3 Dezod S1 kits at my shop 2 without management and 1 with an AEM Standalone. The biggest thing in turboing a NA factory car is research research research. Good luck on your quest to find power but ABSOLUTELY STAY AWAY from Ebay "kits"
Yeah man, I'm really starting to rethink everything anyways. I want to do everything right the first time around. From reading over everything I've posted I sound really impatient, the only thing that's gonna get me is my s___ jacked up. I can just see it, me cruising and deciding to get on it when all of a sudden POOOOOFFF! If I save a little longer and wait until income tax I'll be golden, my camaro ran 11 psi and wasn't tuned so it can be done but I don't think I want to take the chance. Did I mention I have the worst luck ever! Ok my mind is made up, COME INCOME TAX TIME THE TURBO WILL BE MINE, done and tuned properly of course by asap performance. Thanks everyone for your input it was much appreciated and I'll keep you updated
MR makes valid points but if you running a certain inj size or a clutch with certain torque capacity you have stay within those limits until you can progress or update. Pertaining to the 440cc's if you are hitting WOT at mid-high boost then of course they will reach their limit. Also the principle of RESEARCH is very true and can't be understated. This automotive culture is my passion so I love this but most just do it for a hobby. Love and live it.
Thanks for clearing up some of the smoke. Obviously everything has limits and exceeding them is not wise. Despite some incorrect info posted here, 440cc injectors are fine for low boost like 4-6 psi just as the stock clutch is good for a certain torque level but not more.
Not that any of this matters anymore since the OP has realized that he hadn't thought his plans through very well.
Alright! Aem fic with harness acquired for $300. Ok, well one of the most important pieces of my puzzle purchased. Now to order the turbo and bring it down to Mikes Turbos in Miami for some new Garret internals.
