Question about S/C Kit, >'<
I kno that ppl gonna tell me to do the research and things... but blah, i did search everything about it, i just want to get advice from people that have more knowledges than I do. I'm seeing this guy selling his superchager kit near my city( which like 5 hours away), but he only said he got everything on the pics and he doesnt have the injectors, so does it sound good for 1000 pick up? I kno injectors would cost me around 200-300, but i cant see nor know what parts he's missing other than the injectors. So plz help me kno what part do i need more and how much it gonna cost me to complete this kit
Here is his pics:
Here is the pic of part of S/C kit that i saw:
Part Numbers for supercharger kit
TRD, Supercharger Compressor Housing Bracket Replacement Part PTR01-21054
TRD, Emblem, "Supercharged", Plastic Blister Type PTR01-3500E-MB
TRD, Emblem, Small Rectangular, Plastic Bubble Type PTR01-3500T-RD
TRD 2.4AZ S/C, Cold Plug Replacement Part PTR24-21050-00
TRD, Spark Plug PTR24-21055-01
TRD 2.4AZ S/C, Rear Bracket Replacement Part PTR25-21060
TRD 2AZ S/C, Drive Belt Replacement Part PTR30-21060
TRD 2.4AZ S/C, Wire Harness Relocation Kit Replacement Part PTR41-21050
TRD 2.4AZ S/C, Bracket Kit, AC Hose / Wire Harness Relocation Replacement Part PTR41-21051
TRD 2.4AZ S/C, Oil Feed Line T-Adaptor, AN to NPT Fitting, ByPass Valve Tee Replacement Part PTR41-21052
TRD 2.4AZ S/C, Idler Bracket Bolt w / Oil Return Line Hardware Kit Replacement Part PTR41-21053
TRD 2.4AZ S/C, Valve, Bypass Replacement Part PTR41-21054
TRD 2.4AZ S/C, Air Box Assy Kit Lower w/inlet Adaptor Replacement Part PTR41-21055
TRD 2.4AZ S/C, ECU Remap Module Replacement Part PTR41-21056
TRD 2.4AZ S/C, Crank Position Sensor Wire Ext. Assy. Replacement Part PTR41-21057
TRD 2.4AZ S/C, VSV Rubber Mount, VSV Hose & Bypass Valve Hose Kit Replacement Part PTR41-21058
TRD 2.4AZ S/C, Hose, Oil Feed Assy Replacement Part PTR41-21059
TRD 2.4AZ S/C, Rear Mounting Bracket, assembly, Aluminum Cast Replacement Part PTR41-21060
TRD 2.4AZ S/C, Crankshaft Bolt Replacement Part PTR41-21061
TRD 2.4AZ S/C, Idler Pulley Replacement Part PTR41-21062
TRD 2.4AZ S/C, Driven Pulley w/Hardware Kit Replacement Part PTR41-21063
TRD 2.4AZ S/C, Air Box Rubber Mounts & Sleeves Replacement Part PTR41-21064
TRD 2.4AZ S/C, Driven Pulley Shim Asst. Kit Replacement Part PTR41-21065
TRD 2.4AZ S/C, Clamp Kit Replacement Part PTR41-21066
TRD 2.4AZ S/C, Idler Pulley Hardware Kit Replacement Part PTR41-21067
TRD 2.4AZ S/C, Inlet Cover Replacement Part PTR41-21068
TRD 2.4AZ S/C, O-Ring, Supercharged tC Replacement Part PTR41-21069
TRD 2.4AZ S/C, Oil Pan w/ Return Tube Replacement Part PTR41-21160
TRD 2.4AZ S/C, Thermostat, 70C / 160F Replacement Part PTR41-21161
TRD 2.4AZ S/C, Formed Fuel Line Assembly Replacement Part PTR41-21162
TRD 2.4AZ S/C, Fuel Injectors, High-Flow Replacement Part PTR41-21163
TRD 2.4AZ S/C, Gasket, HC Trap Holder, Buna Replacement Part PTR41-21164
TRD 2.4AZ, Supercharger Main Assy. Replacement Part PTR41-21165
TRD 2.4AZ S/C, Insulator, Exhaust: Stamped Replacement Part PTR41-21166
TRD 2.4AZ S/C, Hose Kit: Inlet/Outlet/Bypass Replacement Part PTR41-21167
TRD 2.4AZ S/C, Hose, Water Return Replacement Part PTR41-21168
TRD 2.4AZ S/C, Oil Return Hard Line Assy. Replacement Part PTR41-21169
TRD 2.4AZ S/C, Rear Bracket & Inlet Cover Hardware Replacement Part PTR41-21170
Here is his pics:
Since the s/c is used you need to rebuild it, and needs a new shaft.
Its gonna take a lot of time to find these parts!
missing....
oil pan
radiator hose
fuel line
oil return hard line
thermostat
injectors
spark plugs
ecu flash tool
missing....
oil pan
radiator hose
fuel line
thermostat
injectors
spark plugs
ecu flash tool
Like he said^^^plus if you look at the 3rd pic theres actually stuff missing on that too......parts for the SC are hard to come by now and days, so to answer your question, NO....$1,000 for an incomplete SC kit is not worth it, especially a used one which you'll have to rebuild anyways since you have really no idea on what condition it is in.
my06tc
06-25-2015 12:18 AM
