Question on wideband O2
Searching posts the other day i found that he tc uses a wideband o2 sensor stock. My question is that can this just be hooked up to a wideband gauge or do you still need another sensor with the gauge.
Originally Posted by Scoobasteve4132
Or if you go w/ the dezod turbo it already comes with 2 bungs on the s-pipe!...
I don't believe it would work. I think their S-pipe is specifically made for the downpipe on the turbo...
http://www.dezod.com/cat_turbo_downpipes.cfm
The S-pipe is indeed only meant for our custom downpipe, and will not bolt up to any stock or aftermarket header.
We do sell stainless o2 sensor bungs. You can simply drill a hole in your existing pipe and have a bung welded on.
