questions about supercharger and my strup HEADERS
well soo far i have
tanabe G concept axel exahust
STRup headers
installed on my 08 tc
i was thinking about getting s/c. it dosent really matter if i have a aftermarket headers,, right,? cuase every pics of someone wiht s/c ive seen soo far. has stock headers. with heat shield on them..
would my headers damage the s/c? becuase of no heat shield.?
also. if anyone know about strup headers
will i be able to pass smog? someone people said yes, some people say no..
and i need to be clear. lol thankss
STRup headers
the heat from the headers might damage the s/c's bearings and whatever, but it will definitely void your s/c warranty if you get it installed with headers, or at any place other than a dealer, since a dealer won't install it if you have an aftermarket header on. and yes a header will make you fail the smog check if they hook up your car to a sniffer, or even visual since you have no heat shield covering it.
just pay a little extra and they might pass you lol. but for the heat thing, you can always get bolts welded onto the header so you can use the stock heatshield or just get it jet-hot coated. or you can maybe use header wrap.
To sheild the SC from heat you need to either get the header Jetcoated or use header wrap.........with header wrap you can leterally touch the header while it is runnign with out gettign burnt.......
to pass emissions you need to either replace the cat that is in the stock header by having a high flow cat welded into the S pipe or use the defoulers.....either way will fix the CEL you are gonna get.
dont use header wrap unless you want to crack your header. I can tell you for a fact that having no heat shield on the header does not have any effect on the internal bearings in the supercharger.
wait.. soo
i wont have any problem with the s/c even though my strup header isnt covered with heat shield.?
is it the heat coming from my header that causes damage?
or is it the actual s/c touching my header and causing the damage?
will my strup header touch the s/c???
