Questions on stage 0 zpi?
This is a question that I recently came upon by reading about turbosystems. Most articles say that one of the most important things for a turbo kit is fuel tunning and that there is no such thing as a bolt on system that can be put on and raced right afterwards(without blowing your engine). Iam new to this to this and want to get the zpi stage 0 kit in sept just wondering how the kit is able to be reliable (it seems to be from the happy customers) with no managment. How does the stock ecu compensate for the added air? does it run rich, lean?
also does the kit work fine on stock exhaust?
I think its the stage 1 that has the emanage. the 0 doesnt come with it but you can get it as a option Im sure. Im looking into the stage 0 as well just as soon as tax return comes in. I could be wrong on this, but from what I remember that is the setup
for the stage 0 it says "All fuel and timing tuning already complete" but says nothing of e manage....so i dont know. i was also interested in this kit, could somebody tell me what all i would need after this kit to keep my car reliable?
this has been asked a while ago... and i'm still debating on whether its safe.. but zpi said before that our stock ecu can handle 6psi safely... it would help if zpi can explain to us in detail on why this safe though
You put ont the system and it works. Self contained, needs no tuning other then resetting the stock ECU after you install it. For stage 0 you just need a cheap antifouler to remove the Check Engine Light. The car is definetely strong enough to handle 6psi. Even the auto can handle 6psi safely, no slipping whatsoever.
