quick f/ic question
Old 07-09-2008, 09:38 PM
Blue_TC_Man's Avatar
Default quick f/ic question
I have an 06 tC. If I go ahead and install the F/iC with no map on it will I have any problems? also do I need to run the vacuum boost line to the f/ic if im not running boost?
Thanks
Blue_TC_Man is offline
Old 07-09-2008, 10:05 PM
08superwhite's Avatar
just curious but why would you want the f/ic if you aren't running boost?
08superwhite is offline
Old 07-09-2008, 10:07 PM
im running a 100shot of nitrous and I need to remove some ignition timing and dial in my a/f ratio
Old 07-09-2008, 10:25 PM
ok, then no you shouldn't need to hook up the vacuum signal. you would just set it up by tps position and rpms. that is if you are running the nitrous and 100% throttle which is the only way you should.
Old 07-09-2008, 10:32 PM
Mr_Meaty's Avatar
You cannot hook it up with no map as it will make everything zeroed out...you will need a base map for stock injectors.
They have one on the aempower.com forums.
Mr_Meaty is offline
Old 07-09-2008, 10:34 PM
awesome thanks
yeah its got a full window switch system first gear lockout, 3000-6000rpm spray window, and tps WOT switch.
hooking it up without a tune on it wont give me any problems will it?
Old 07-09-2008, 10:36 PM
ok thanks ill grab that
Old 07-09-2008, 11:01 PM
garabaldy's Avatar
Why does he need a base map with stock injectors? "0" means no change from the factory output to the injectors, timing, etc. Explain please........
garabaldy is offline
Old 07-09-2008, 11:07 PM
coryjames's Avatar
i second that
coryjames is offline
Mr_Meaty's Avatar
yeah...your probably right...but when I put the F/ic on my car wiht no map, it sputtered worse then when I had nothing on at all...of couse this was after I installed my kit.
I also spoke with dezod, and they said a 0 map is blank and will not work as it's not a base map...it's not ONLY the fuel map but the ignition that needs to be adjusted to make a stock car run stock...i think....i dunno, but good to have just in case, right?
Mr_Meaty is offline
Old 07-09-2008, 11:10 PM
oh they meant with a turbo on the car. Im not spraying anytime before i tune as long as the car will run like its does right now with it on 0 i should be fine
Old 07-09-2008, 11:56 PM
Mr_Meaty's Avatar
yeah...I don't think so. But I sent you a base map anyway...it's not tuned for any boost.
Just plug in your f/ic and drive around...if it dies, put on the map I sent you...no worries.
Mr_Meaty is offline
Old 07-09-2008, 11:59 PM
Mr_Meaty's Avatar
see, not only will it be 0 in the fuel map, but it will be 0 voltage in the 02 and ignition tables, and the maf table will be 0 as well...I just don't think it will work.
Mr_Meaty is offline
Old 07-10-2008, 12:02 AM
awesome thanks for the map man
Old 07-10-2008, 02:36 AM
thendawg's Avatar
Set everything you dont want to use (such as maf remapping, etc) to percent thatll make it pass through factory
thendawg is offline
Old 07-10-2008, 06:00 AM
Mr_Meaty's Avatar
good idea...that should work with all 0s
Mr_Meaty is offline
Old 07-13-2008, 06:19 PM
ok the map you sent man man instantly killed the car, and the zeroed out map makes it bounce like hell I unplugged the F/ic (harness is still in) and now car wont even start.
Old 07-13-2008, 06:28 PM
coryjames's Avatar
put the jumper wire that came with the kit if the harness is in and no fic
Old 07-13-2008, 06:32 PM
ok well i pulled out the harness and it cranked but now it idles like ____
Old 07-13-2008, 06:38 PM
Mr_Meaty's Avatar
clear your ECU...
Mr_Meaty is offline
Quick Reply: quick f/ic question
