Is This For Real??
i dont think so cause the intake on the sc'er connects to the inlet on top, and u can see the whole piece on the sc'er where it connects and the intake is going back towards the tb position, and u could just cut ur intake down as it is now and it would work, just that there is a possibly that it may cause u to run leaned out
thats what i thought, and it really doesnt look like it is, i have a trd sc'er on my car and from what i see in the pic it looks like the sc'er is in the process of being installed cause its not all there, and the intake is just run to the tb, when it should go... intake - sc'er inlet - sc'er outlet - tb.
the sensor on the intake looks closer to the bypass valve, cause when i looke at a pic of mine it was a lil further away,
so maybe the have a different pipe that connects the intake to the tb, but also conect to the charger from what i think im seeing and calling it a "t-bone" connection
Re: Is This For Real??
look at the turbine of the s/c, the inlet is not connected to anything, usually a rubber/silicone hose would be there, which it clearly isnt.
and would you really buy a s/c just so you could use a 200 dollar intake?
Yeah its not connected. You can see the S/C inlet and the intake clearly runs toward the back of the engine. IDK why they set this motor up like this for display... I guess just to show off what you can do with it.
BlingSlade
10-19-2016 12:39 AM
JonnyBigBoss
09-26-2015 08:31 PM
