Rippmods supercharger cams
Ross from Rippmods said that his cams are good for both turbo's and s/c's - it has crossed my mind to get them next time I go back to get retuned and put my smaller pulley on ..... it all depends. If you are running 9.5 or even 10.5lbs you shouldnt need bigger injectors. Karl was running 12lbs so he maxed them out at around 290whp - The only question is if you should upgrade your fuel pump if adding the cams (and running 9.5-10.5lbs boost) .... I think the answer to that would be yes.
Karl topped out at 290 WHP with the 410cc injectors. That's with them running at 100% Duty cycle which is bad... You never want Injectors to run that much.
He upgraded to the 550cc Deatschwerks injectors and got up to 311.
I don't think you need to upgrade the fuel pump really, but it is a good idea.
Thats the thing - with 10.5lbs and my setup it should be around 260whp - cams .... 280whp - I would need different injectors if I went with new cams because 290whp was maxing them out (like you said)
steeze69
05-24-2021 02:57 AM
rain7905643
06-13-2018 05:29 AM
