s/c boost reading
Originally Posted by HEYitzMEEE
Which BPV are you using? If you're using a forge you'll see boost in the 3k RPMs if you're giving enough gas to start boosting. I tapped mine into the vac line where the throttle body is.
i got a BPV from a member here like a year ago and forgot the name of it. i was told that it should hold up to 12 lbs.
maybe i should take it to a empty strip and get on it and see if it reads 9.5lbs or better.
ic ic... thats good to hear. another Q is. what are the #s my wide band should be reading? sorry for all the stupid Qs. just had gauges put in and im now to this. once again thanks for all your help.
9.5 pulley,stock s/c intake (K&N drop in filter), weapon r header & s pipe, meagan mid pipe, greddy sp2 exhaust,
ColonelSanders85
12-09-2020 09:44 AM
my06tc
06-25-2015 12:18 AM
spawnconnery
12-18-2014 08:38 PM
