S/C pulley noise?
#82
#93
Also I realized that no one posted up gompka diy videos on how to remove them.
http://23.25.49.254/D.I.Y.html
And seeing where you are at now you should watch video part 4
hope that helps
hope that helps
#99
you can get a pack at your local auto parts store. they usually sell 5 in a box. it might be located near the grease/oil section.
Then you have to use a drill and drill into your bearing housing.
You also need a "tap and die kit" to create threads in the housing so that you can screw in the grease fitting.
