S/C pulley noise?
#121
Yea ill be doing mine soon. I still need to update the.blower.
Do you have all the lite pulleys,crank, alternator, What belt are you useing. Im thinking of just getting them. But I want to stay stock size witch ones did you get.
#122
lightweight pulleys shouldn't cause an issue, its changing the diameters of the other pulleys where you might negatively affect the spin of the supercharger pulley that you don't want.
#123
Mossy performance light crank same size oem, OBX Lite pulley same size oem OBX alternator
Mad small lol a
_____ to find a belt to
Go with that and nst 9.5 I forgot the number got it at napa though I'll let u know
Mad small lol a
#124
Can we use any of the bearings that's on that web site, or any site that's the same size . Or is it just that ONE in the link.
#126
Would I be able to use any of these.
http://www.vxb.com/page/bearings/PROD/Kit7549
http://www.vxb.com/page/bearings/PROD/Kit8165
Are they even worth it.
I'm going to replace my blower so might as well do the shaft its been a year already lol
#127
DO NOT USE THESE BEARINGS!!!! Im positive they will melt and you will not like it. http://www.vxb.com/page/bearings/PROD/Kit7549
#128
OK so both are not good.
how about these
http://www.usabearingsandbelts.com/m...-25x52x15.html
I'm just trying to see what else is out there that will also work maybe be better.
how about these
#129
I used these bearings idk how long they will last but will see
http://www.zorotools.com/g/00069115/k-G2248057/
#130
So after all this the dam pulley area is squealing again other than the belt I'm lost on what is causing this!!! The belt has been on since June less than 1500 miles on it the belt is tight fit
#131
The 6205 bearings have difference speed ratings, the ones i posted on grainger are at least 12,000 rpm. It also doesn't hurt to get bearings with contact-less seals to keep the friction down.
#132
Did you use loc-tite 680 on the bearing housing? Could be bearings spinning in the housing.... Also, check your idler bearings, those go out often also.
#133
Didn't use lock tite but I find it hard to believe that's what's causing it since it was doing it before and I don't think these bearings were ever replaced. The sound is coming from the pulley for sure idlers are quiet. The shaft looked perfect when apart and those bearings wouldn't move at all after I put them on they spun freely as well.
#134
I just hope its not something other than the S/C going bad on your tc, like the belt tensioner
#135
I emailed the guy he said its speed rated to 13000 and hi temp of 250. And how would I know about the less seals??
#136
