S/C Tuning Question
Old 10-02-2008, 11:43 PM
JrTcs's Avatar
Originally Posted by BuddhasTC
440's are fine...with the 9.5 lb pulley and CAI...do not use the TRD reflash because you will run lean at WOT...u need a tune with at least a piggyback ECU...which the emanage blue is fine. if you don't get the CAI then the TRD reflash is fine
naa that's been proven wrong many many times. ive seen several dyno sheets showing that the a/f ratios are perfectly fine with a CAI on the s/c and trd tune. it wont lean out if the intake is designed correctly.
granted there are a couple of people who did this and were ok...but i have also seen more cases here alone that the exact opposite was true...better safe than sorry.
I would tune it to be on the safe side more instances where its running lean than ok.
JrTcs is offline
JrTcs's Avatar
JrTcs is offline
JrTcs's Avatar
JrTcs is offline
JrTcs's Avatar
JrTcs is offline
JrTcs's Avatar
JrTcs is offline
JrTcs's Avatar
JrTcs is offline
Old 10-03-2008, 02:08 AM
unxpectederror's Avatar
wow wtf happened there ... ive seen double posts but nothing like that before...
unxpectederror is offline
Old 10-03-2008, 02:53 AM
equinox2355's Avatar
M-M-M-M-M-M-M-M-M-M-M-M-M-M-M-M-M-M-MULTI POST!
equinox2355 is offline
Old 10-03-2008, 07:49 PM
BuddhasTC's Avatar
he's "post whoring" so he can get up to 50 posts and sell something probably
BuddhasTC is offline
Old 10-03-2008, 08:17 PM
TokenAsianGuy's Avatar
LMAO!
TokenAsianGuy is offline
Old 10-03-2008, 10:24 PM
GhoZt's Avatar
Looks like your right.
GhoZt is offline
Old 10-22-2009, 03:39 AM
AZGuy's Avatar
Small thread jack. I am planning on getting a unichip for my car and getting tuned for the 9.5 pulley which I am running now. I have seen folks saying a point both ways if anyone can clarify, I have the TRD reflash am I ok to tune with the unichip or should I get another ECU without the reflash? I have seen people saying you will have trouble with timing but I don't understand this part, does the TRD reflash lock out otherwise adjustbale parameters on a stock ECU?
I would like the ability to remove the piggyback at some point and be able to return the car to SC stock trim.
AZGuy is offline
Old 10-23-2009, 04:39 AM
garynkim's Avatar
i would perfer the greddy ult. instead. but if you in budget the blue works fine.. but i believe its better overall performance and drivable then the blue because you can fine tune it.
garynkim is offline
Old 10-23-2009, 04:40 AM
garynkim's Avatar
your fine with the piggy back later on goin back to stock sc trim.. right now i have fully built motor and running on the trd sc, but have not got in tune yet on my greddy ult. with trd flash ecu..
garynkim is offline
Old 10-23-2009, 05:08 AM
AZGuy's Avatar
Let us know how that goes tuning with the TRD flash, I just want to know if I should plan on getting another ECU so I can keep one with the trd flash since its cheaper just to buy a stock one for like 40 bucks.
AZGuy is offline
Old 10-23-2009, 01:25 PM
syberspyder's Avatar
Link to $40 ECU? Junkyard?
syberspyder is offline
Old 10-24-2009, 12:43 AM
AZGuy's Avatar
http://cgi.ebay.com/ebaymotors/07-En...ltDomainQ5f100
http://cgi.ebay.com/ebaymotors/SCION...Q5fAccessories
If you keep an eye out on ebay you can find them cheap.
AZGuy is offline
Old 10-24-2009, 01:26 AM
Thanks AZGuy! Didn't think to look on ebay, what worries me is that it retails for $900, and somehow they're only selling in for $40.
Old 10-24-2009, 02:18 AM
AZGuy's Avatar
They are salvaged, and they are still subject to supply and demand not a common item to go out plus they include serial numbers so I wouldn't worry.
AZGuy is offline
bootlgr
01-26-2016 01:22 AM
Greg S
05-28-2015 12:46 AM
Scionxa180
03-13-2015 04:39 AM
TotalChaos
13
02-04-2015 10:24 PM
elzy0000
01-16-2004 04:31 PM
Quick Reply: S/C Tuning Question
