SC GUYS ONLY... UPCOMING PRODUCT.. GAUGING INTEREST.....
Old 08-29-2006, 02:19 AM
  #121
Boosted06's Avatar
Nice , still cant wait fit the intake though
Boosted06 is offline
Old 08-29-2006, 02:52 AM
  #122
navylife59's Avatar
Does anyone actually have boost gauge readings at the TB on the TRD setup? I'm barely cracking 5PSI on a 9 PSI pulley.
navylife59 is offline
Old 08-29-2006, 02:55 AM
  #123
Garage1217's Avatar
You have belt slipping issues. Have you replaced your belt..? Also could be a boost leak.
Garage1217 is offline
Old 08-29-2006, 02:57 AM
  #124
Nick06tC's Avatar
With th 9.5 NST pulley, I am hitting close to 10PSI. Its hard to tell exactly what it is because you will only see your peak PSI for a brief second.
Nick06tC is offline
Old 08-29-2006, 02:58 AM
  #125
jwaggz82's Avatar
here is the pic - i have it as a broken link (on the one garage posted)
jwaggz82 is offline
Old 08-29-2006, 06:41 PM
  #126
navylife59's Avatar
Went thru several belt sizes and have a gatorback on there now. I'm thinking boost leak
Old 08-30-2006, 02:21 PM
  #127
Boosted06's Avatar
Yeah its prob, boost leak, do you have a boost gauge
Old 09-01-2006, 09:30 PM
  #128
navylife59's Avatar
FAZE
Old 09-04-2006, 03:04 AM
  #129
Boosted06's Avatar
you back yet
Old 09-04-2006, 05:32 AM
  #130
kocho333's Avatar
navylife59 werd man i had to zip tie my hoses, and check the connection to the back of the gauge itself, mine is still leaking!, (im puttin down 6psi easy wit stock pulley...when my gauge is workin properly)
kocho333 is offline
Old 09-04-2006, 05:19 PM
  #131
navylife59's Avatar
Default !
I created a vacuum distribution manifold and replumbed the vacuum lines. I added 3 more shims to my TurboXS RPV-25. It seems to be running smoother, but still no 9PSI. I plan on converting to a BOV once I get my Greddy Ultimate with the MAP sensor installed tomorrow. So long MAF. I am also goign to try to find a smaller belt and see if anything changes.
I have been asking about peps with headers and s-pipes and their PSI/Hg readings specifically for a reason. A while back on some forum there was a discussion about PSI loss after a header install. The initial theory was that back pressure was needed to make boost. It was discounted by many as another problem. I, however, cannot discount the fact that there is some physics to back up that notion. Albeit not an inversly proportional relationship between intake boost and backpressure exhaust as in turbo applications, there is an indirect relationship between these two functions with supercharged applications.
First, let's discuss the turbo application. Turbo boost pressure is directly proportional to exhaust system pressure. The more flow that a system has, the more energy that can be absorbed by the turbine impeller. A restrictive exhaust system creates more backpressure which equates to less energy for the turbine. It is important to note that as the exhaust system backpressure is decreased (more energy) the turbine becomes more efficient (overcoming impeller weight, bearing friction, and centrifugalforces).
S/C differ as in they utilize direct mechanical energy from the engine. Depending on your type and application, the boost pressure is directly proportional to engine speed until the BPV or BOV opens. You get a linear boost curve that is very predictable. WWII fighter planes had 2-stage superchargers that allowed 2 different boost levels for low and high altitude flight. Modern automotive applications do not so as to make the system more reliable and cheaper. Also the engines utilizing this setup were mainly Merlin V-12 engines producing over 2,000 HP. Hmmm, a tC with a Merlin?
Now we need to discuss valve overlap or cam duration. N/A engine benefit greatly from a higher duration camshaft, especially, on high compression engines (higher cylinder pressures). At the point of valve overlap in the cam timing (duration), blow-thru occurs. This blow-thru allows the low pressure exhaust side (assuming a properly designed and tuned exhaust) to evacuate the cylinder bore, thusly, drawing in a larger amount of intake charge. Turbos benefit bacause the wastegate will allow more energy to be scavenged from the exhaust flow to keep the cylinder pressure maintained. This is why turbo applications can benefit from camshafts with higher durations. S/C cannot because the amount of boost is directly proportional to crankshaft rotation. There is not a marketed (it can be done) method to increase the S/C's boost output to maintain the desired cylinder pressure. S/C applications benefit from higher lift camshafts and not duration.
In a nutshell, this is only a hypothesis. I have done no testing or researched such . The thought is simply if an exhaust system were to be tuned to allow a lower pressure to reside at the collector and create more blow-thru at valve overlap (assuming sufficient duration), then there would be a proportionate reduction in cylinder pressure. This must be overcome by increasing the amount of pressure in the intake charge. The turbo can, the S/C cannot unless a smaller pulley is installed.
I am no physics major, but I did sleep with one at a Holiday Inn Express!!!
Old 09-05-2006, 06:28 AM
  #132
ryno379's Avatar
Default Re: !
After reading all that, this is what I came away with.
ryno379 is offline
Old 09-05-2006, 06:29 PM
  #133
Garage1217's Avatar
Hey guys sorry for the delay in dyno, I broke a supercharger mount and am fighting with the dealer for them to replace it. Hopefully it will be in asap or I will have the current welded.
Old 09-05-2006, 06:47 PM
  #134
rOmEro's Avatar
What kind of hassle/excuses are you getting from the dealer for the mount?
Sorry, I dont mean to thread jack!
rOmEro is offline
Old 09-05-2006, 07:27 PM
  #135
release2063's Avatar
i would buy one when it comes out
release2063 is offline
Old 09-06-2006, 03:31 AM
  #136
navylife59's Avatar
Default Re: !
Yeah its a lil wordy (nerdy) but it is a possibility to explore. You add piping to your intake path and you loose boost. I realize that boost is only brought up n the cylinder under the compression stroke. Just hypothesising here to see if anyone else ia experiencing any changes in overall boost levels.
Old 09-07-2006, 04:48 PM
  #137
Boosted06's Avatar
where's it at man, i need that intake, jk . But seriously
Old 09-07-2006, 05:06 PM
  #138
Garage1217's Avatar
Yo guys, Just so you know I am not feeding you guys crap, Here is the bracket I broke welded up finally. Will start putting it back together tommorow. I am just as excited as all of you to hit the dyno!
Old 09-07-2006, 05:10 PM
  #139
Nick06tC's Avatar
Garage:
Whats the word on removal of this bracket, and how about driving with it broken? Mine isnt borken YET, but just wondering what it could cause if not noticed.
Nick06tC is offline
Old 09-07-2006, 05:30 PM
  #140
Garage1217's Avatar
mine was probably broken for 1-2K miles. Never noticed it until I looked.
Quick Reply: SC GUYS ONLY... UPCOMING PRODUCT.. GAUGING INTEREST.....
