Scary Turbonetics Kit issues... Again
I have the Turbonetics Stage 1 kit on my 06.
About 2 months ago I had the Down Pipe replaced because the wastegate flange cracked and was falling off. Turbonetics stated that they knew of this problem and have re-done the pipe and put a beefier flange with stronger welds...
Today, I inspected my whole turbo system and noticed that there is a small crack forming around the flange once again... and there is some black carbon buildup from exhaust leaking from the crack already.
As well, I looked at the bottom of the flange that meets up with the Turbine Housing and guess what... Oil leaking. Looks like my BRAND new Turbonetics turbo has blown a seal again. I just had it replaced a month ago for the same issue... I have lots of blue smoke coming out under mild boost. I drive the car very lightly, It is used for driving 2 miles a day back and forth to work, I rarely ever hit full boost only occasionaly on the freeway. I do not have a turbo-timer but I sit in my car for a full 2-3 minutes after a drive, even under mild driving.
I really can't believe that I am going to have to do all of that work again. Taking it off, being without a car for 2 weeks and installing it again and wasting more money on TS-1 oil that I just put in.
I have heard others are having many similar problems with this kit... Please post here if you have had any of these problems, I would like to know what they told you and what they were able to resolve with you.
Thanks.
Thanks.
Chris from ohio went through two also. Tell them to send you more oil and that you are really getting ticked off.
I opted to just sell the 50 trim turbo and get a 60 trim one instead. With a new tune car runs great and havent had issues yet (knocks on wood).
You get your car tuned?
I called Turbonetics today and the Customer Service Rep that I spoke to said "You'd be surprised usually the problem is not with the Turbo" ... Basically implying the problem is me. He asked if there were any kinks in the lines. And I said of course not. He followed by asking me "Did you even look to see if there are any kinked lines?"
Who does this dude take me for?
Regardless, He told me to take out my downpipe and Turbo and send it in to them. Shipping expenses on me...
I am pretty frustrated. Even if I do get a new turbo, who is to say this next one wont do the same thing.
The same things happened to me but once my turbo went out I ahd T-netcis replace it but I have it at home and replaces it with a Garrett GT-3076R, much better turbo and we'll see how long it lasts.
Sir,
Let me first apologize for your experience. Without going to deep details we are aware that a number of people who have purchased our turbo kit have run into this issue that you are describing. We are currently working on a fix and I'm expecting we would have a solution by the Fall. My personal take is that if I owned one of these kits I would run a turbo with a wet center section. If this is something that you would be interested in please let me know.
If you have any other questions or concerns please feel free to get ahold of me directly. My email address is rwynn@turboneticsinc.com and my direct number is 805-426-3417.
Reggie Wynn
Sales Manager
Turbonetics Inc.
Reggie Wynn
Sales Manager
Turbonetics Inc.
I have shot you an eMail. Thank you for your quick response and I appreciate the concern.
Ive been trying to get a Wter cooled turbo from turbonetics for awhile now. I keep hearing its in the future. If turbonetics thinks we need water bearing sectiosn then why not sell the kits that way or at least offer a upgrade to those of us who have had problems. My brother and I are both on our 2nd turbos. Also when you guys come up with a fix for this problem what will happen to us who already have the kits. Or will it only be on new kits?
To answer your last question all of the new kits will have water cooled turbos once we document the install and what not.
Reggie Wynn
Sales Manager
Turbonetics Inc.
Reggie Wynn
Sales Manager
Turbonetics Inc.
Cool, Please keep us updated Reggie!
hey guys,
sorry...just saw this. I did do a water cooled center section for the tC. I'll be getting all my info together and posting a DIY here and on www.turboneticsownersclub.com
the problem with the failed seals seems to be caused by the excess heat. The water cooled center will eliminate this problem as it will drop temps by nearly 400 deg.
I would suggest looking into an oil cooler as it will raise oil temps especially when pushed hard. I suggest an oil cooler regardless of the type of turbo you have. All modern factory turbos run this setup to promote extended turbo life.
feel free to hit me up in the mean time should you have any questions
I do believe that Turbonetics is working on gathering up all the appropriate parts for a complete install on the tC. All you will need to do is send in the turbo and have the section swapped out.
It's not a difficult install at all and definitely worth it.
Originally Posted by jam0321
hey guys,
I cant wait for the DIY on the water cooled center. I would love to hook that up and solve my problems
