ScionGT35R 476whp@19psi pics all over
Old 11-23-2007, 02:46 PM
  #301
Team No Limitz
Simplyscion's Avatar
Originally Posted by soros151
Originally Posted by jwaggz82
^ oh yea - ha. I feel ya with the money situation - I dont know what its like in PR but NJ is surely not the cheapest state to live in ..... Its funny because in my other parts of the USA (minus a few states) the cost of living is cut by around 1/2.
PR has one of the highest State Tax. 7%.
Suffok County Long Island NY-8.625%
Simplyscion is offline
Old 11-23-2007, 02:54 PM
  #302
soros151's Avatar
Dayummm!!!
soros151 is offline
Old 11-23-2007, 03:10 PM
  #303
blitztc06's Avatar
how come the 4th pulley cant be replaced, first time seeing it since its pretty much in the back hidden, i have no idea what it is please tell me....(alt, wp, crank, ????) power steering?
blitztc06 is offline
Old 11-23-2007, 04:46 PM
  #304
jwaggz82's Avatar
^ yea nj tax is 7%
jwaggz82 is offline
Old 11-23-2007, 06:22 PM
  #305
Mecanica_Pito's Avatar
Power Steering
Pito
Mecanica_Pito is offline
Old 11-23-2007, 06:50 PM
  #306
blitztc06's Avatar
i knew someone with a pos fiero and took off power steering "few ponies" from what he said, that car was impossible to move from a stand still, you actually had to be rolling to move the wheel, have NST make you a custom blue one even if its the same size and weight just to look all done on that side of the motor
Old 11-23-2007, 08:03 PM
  #307
ScionGT35R's Avatar
Plus arbitrios that it's a 6.6 more!!!
ScionGT35R is offline
Old 11-23-2007, 08:06 PM
  #308
ScionGT35R's Avatar
Isn't better to paint it blue or paint them all the same color??
Old 11-24-2007, 01:42 AM
  #309
Well, I finished installing both in-tank Walbro's today. It took a lot of work to do but I think it will be worth it ....
This is the block and pumps along with a custom Stainless Steel bracket that holds the pumps in position .
This is the top of the pump assembly before the finishing touches. I fired the pumps in the bench only to see if they where both working and everything was OK. You can see the -8 feed line fitting and the -6 return line fitting. The stock feed port is blocked cause it is no longer in use .
In this photos you can see all the setup including the sending unit and the return line that faces opposite of the pumps. Here you can also see the rubber isolator at the very end of the bracket to insulate it from the pumps. I also installed a rubber insulator between the bracket and the block to prevent any vibration and noise in the cabin .
Finally I changed the position of the Aeromoitve pressure regulator to the lower part of the driver's side shock tower, installed the new _8 feed line from the tank to the rail and began wiring the pumps to the new 40 amp fuel pump relay ...
Tomorrow I will try to finish it off and also install the brand new NOS system sitting in my living room now..... ....
I will update tomorrow,
Pito
Old 11-24-2007, 02:56 AM
  #310
soros151's Avatar
Pito, this setups gets even nmore killer everytime I come in. Keep the PR power going! Qs LA Q?
soros151 is offline
Old 11-24-2007, 03:22 AM
  #311
jwaggz82's Avatar
What size shot are you going to run? 50shot?
jwaggz82 is offline
Old 11-24-2007, 03:47 AM
  #312
soros151's Avatar
Well I can use a .44, no?
soros151 is offline
Old 11-24-2007, 04:28 AM
  #313
I am not a big fan of NOS so I will begin with a shot of 50 but I know for a fact that ScionGT35R will not want to stop at 50 ....
Pito
Old 11-24-2007, 01:25 PM
  #314
ScionGT35R's Avatar
Pito
^^ You're so damn rigth!!!!!!!!
Old 11-24-2007, 01:47 PM
  #315
RSracer's Avatar
I tried searching the thread w/ no luck...
Did you have to knotch the block for the K1 rods to fit?
RSracer is offline
Old 11-24-2007, 05:00 PM
  #316
etsnet's Avatar
He had said in another thread that he didn't have to notch with the K1 rods.
etsnet is offline
Old 11-24-2007, 05:09 PM
  #317
Streeter's Avatar
holy frikking crap!!
What exactly is going on here?!
Streeter is offline
Old 11-24-2007, 05:35 PM
  #318
RSracer's Avatar
Awesome, thanks
RSracer is offline
Old 11-24-2007, 05:43 PM
  #319
ScionGT35R's Avatar
That's correct!!!!!!
Old 11-26-2007, 01:39 AM
  #320
Sorry etsnet and RSracer! No clearance problems with the K1 rods....
I took a lot of pictures while assembling the engine and I have plans of making something like a how to and it was going to be explained in that post .
Pito
Quick Reply: ScionGT35R 476whp@19psi pics all over
