ScionGT35R 476whp@19psi pics all over
Old 12-02-2007, 06:37 PM
  #401
etsnet's Avatar
Would it be safe to say that using something like lock tight would be good for that? Just asking so I know when we get mine back together if I should use it.
etsnet is offline
Old 12-02-2007, 06:47 PM
  #402
malloynx's Avatar
was the nut torqued to factory spec??? sorry to see your misfortune..
i had a simliar problem on one of my builds. the piston ring came out of the piston and locked up the cyinder causing the rod to see daylight
malloynx is offline
Old 12-02-2007, 06:53 PM
  #403
mikescion's Avatar
ouch
mikescion is offline
Old 12-02-2007, 07:25 PM
  #404
krazylowgsx's Avatar
i told you guys not to break anything. on the bright side... it looks like the intake manifold held up at 21psi..lmao.
also.. i know your using an emanage ultimate and pushing it to the limits, but dont you guys think that the factory throttle body would be a huge restriction too?
krazylowgsx is offline
Old 12-02-2007, 09:53 PM
  #405
TCFROEZEL's Avatar
Originally Posted by Mecanica_Pito
Well, We opened the bottom end today and found the root cause of the problem. The nut that holds the oil pump sprocket to the oil pump got loose and falled in the oil pan where it was sucked by the oil pickup tube.
You can see the nut inside the pickup tube here.....
This confirms what I said before opening the engine. The problem was caused by lubrication failure but not because of the higher rev limit as it was caused by the oil pump failing to work because of the nut that is supposed to hold it.
The sad part is the crankshaft is damaged but salvageable and the K1 connecting rods are OK. We will keep you guys informed of the next step as sonn as we decide what to do. We might resize the cranksahft or install a new one. We will see....
Pito
WOW.
that is very sad to hear of the oil pump failure.
did you shim the Oil Pump ?
or just left it stock ?
i have damaged crankshafts in the past.
i would suggest you to just change the shaft.
but too bad to hear of the engine damage.
hope you assemble fast and rach your goal.
TCFROEZEL is offline
Old 12-02-2007, 09:57 PM
  #406
bBlover's Avatar
wow thats hot!
bBlover is offline
Old 12-02-2007, 10:34 PM
  #407
Mecanica_Pito's Avatar
Let's just say that I will definitely use Loctite when installing the sprocket to the oil pump the next time..... What the hell ..... I might put another locking nut in there to be safe.
Pito
Mecanica_Pito is offline
Old 12-02-2007, 10:39 PM
  #408
Yes it did. The incident with the manifold was the fault of the polisher as the fabricator is used to making manifolds that hold a lot of boost, NOS and even backfires .....
Yes the throttle is now a priority but we are looking outside the box for a solution . Also dont remember that the e-Manage will be replaced next year..
Pito
Old 12-02-2007, 10:45 PM
  #409
Yes it was torqued to spec but no threadlocker was used. Maybe we just had bad luck!!!!
....i had a simliar problem on one of my builds. the piston ring came out of the piston and locked up the cyinder causing the rod to see daylight
Sometimes **** happens and although it is bad we have to think that we are walking on new grounds and things will always happen: some very bad and some not that bad !!
Pito
Old 12-02-2007, 10:53 PM
  #410
Originally Posted by TCFROEZEL
WOW.
or just left it stock ?.....
Yes the pump was shimed with a 3mm spacer inside the bolt!!
....i have damaged crankshafts in the past.
I have too ... Some people have bad experiences with reworked crankshafts and not to lie to you I considered changing it but this crankshaft is knife-edged and that is some money that will be lost if we change the crankshaft that could be saved by resizing the same crank!!!
Pito
Old 12-02-2007, 10:58 PM
  #411
Here is the Dyno graph ploting the graph from the old engine and the new one!!! Remember I didn't had the time to finish the tune. I was working with the fuel map modifications needed to raise the rev limit in a safe way then tune for RAW POWER
And this is the car after a little face lift it received before going to the dyno!!!!
Pito
Old 12-03-2007, 12:47 AM
  #412
TCFROEZEL's Avatar
HA HA. ese raton se ve bien.
Seibon Hood looks good on it.
well i would change the crankshaft though.
you are the tuner you can make the desiscion.
Old 12-03-2007, 01:03 AM
  #413
I hear you on the crank!! We are going to remove the crank and have a serious conversation with the owner of the machine shop and then make the decision taking in consideration all the facts.
Pito
Old 12-03-2007, 02:08 AM
  #414
soros151's Avatar
So podemos suponer q la bomba de aceite tiene sus limites, o fue algo de "casualidad"?
soros151 is offline
Old 12-03-2007, 02:20 AM
  #415
"Casualidad"
Pito
Old 12-03-2007, 02:31 AM
  #416
soros151's Avatar
Cool! Thats good to know.
soros151 is offline
Old 12-03-2007, 03:55 AM
  #417
mikescion's Avatar
sorry to ask again but what was the AFR under fullboost, what was the injector duty cycle at under full boost and FP at idle if you don't mind me asking. sorry to be a pain with the questions....
Old 12-03-2007, 04:49 AM
  #418
Sgtfluffy16's Avatar
sorry to kinda bust on u but thats all u ran at the track a 14.9..
i ran a 15.2 at 91 MPH on a stock motor.. just intake, cat back exhaust, and a lightened crank pulley.. and i know i can do better times..that was my first time ever running at a track..on stock wheels and tires
Sgtfluffy16 is offline
Old 12-03-2007, 04:50 AM
  #419
that is to MikeScion BTW..
Old 12-03-2007, 05:35 AM
  #420
AFR' was 11.6 on low boost and a bit richer at about 11.3 at 19 psi. At 19psi the duty cycle was 79% at 19 psi of boost and 7,400 rpm's if I remember correctly (I will check on the laptop logs tomorrow)...
Fuel Pressure at idle is 42 psi...
Pito
Quick Reply: ScionGT35R 476whp@19psi pics all over
