ScionGT35R 476whp@19psi pics all over
Old 10-31-2007, 03:35 PM
  #81
cessblood's Avatar
Originally Posted by ScionGT35R
More pics with some other parts so you guys could have an idea of how will look.
cessblood is offline
Old 10-31-2007, 04:31 PM
  #82
ScionGT35R's Avatar
He better! I'm anxious to see it running!!
x2
You are lost, bro.
study and work you know how it goes!
again????
ScionGT35R is offline
  #83
soros151's Avatar
x2
You are lost, bro.
I do know how it goes, thats the problem. :D
soros151 is offline
Old 10-31-2007, 04:37 PM
  #84
soros151's Avatar
x2
You are lost, bro.
again????
soros151 is offline
Old 10-31-2007, 05:09 PM
  #85
trdtcpr's Avatar
x2
You are lost, bro.
again????
i need to study to get money and be like you when i grow up!
trdtcpr is offline
Old 10-31-2007, 05:31 PM
  #86
Mecanica_Pito's Avatar
Originally Posted by mikescion
Thank you ScionGT35r for keeping us up to date with the build and any problems that you ran into and how to fix them. Let me know if you can when its all done what the fuel setup is going to be that would help me alot..
Originally we had a Walbro in-tank 255lph fuel pump using the stock lines to the rail and added an Aeromotive 1:1 pressure regulator to the stock fuel rail and also added a -6 fuel line to the tank to be used as a return line. We had 750cc Siemens Deka low impedance injectors with in-line resistors so the E-manage can work correctly.
Now we are going to install a second Walbro 255lph in-tank: so we are going to have twin Walbro's in the tank with a new -8 line going from the Fuel tank to the fuel rail and using the same -6 line as a return. We switched to a custom Fuel rail and kept the same Aeromotive regulator directly attached to the rail.
At that time we are going to test the setup as indicated and see what numbers we can achieve with the 750cc injectors. Normally I would install bigger injectors but since we are still running the E-manage I am reluctant to go bigger because it will be very difficult for the piggy back to run correctly at part throttle and the fuel consumption will be horrible!!
Pito
Mecanica_Pito is offline
Old 10-31-2007, 05:46 PM
  #87
mikescion's Avatar
I'm sorry i never knew about in-line resistors so the emanage can work correctly... can you shine some light on that for me? I was reading on another forum for other cars like The RSX and they are raising there idle to 1000rpms and running 850cc's on a piggy back would that work for our car?
mikescion is offline
Old 10-31-2007, 06:05 PM
  #88
It can only work with high impedance injectors. Greddy, Turbonetics, Dezod and others include with their kits high impedance injectors so that it is plug & play. We bought our low impedance injectors like new very cheap but it required adding the resistors.
Correct me if I am wrong but I think RSX 's are not DBW (drive by wire) so they can rise the idle rpm's. On the tC it is not possible to do so.
It might work, might not: the question is if it will run good in every day driving and if the fuel consumption will be tolerable.
Pito
Old 10-31-2007, 10:48 PM
  #89
mikescion's Avatar
oh I forgot the RSX was DBW sorry for the question and thank you for the quick answer...
Old 10-31-2007, 11:18 PM
  #90
jwaggz82's Avatar
^ do you mean not dbw?
jwaggz82 is offline
Old 11-01-2007, 12:31 AM
  #91
318_tC's Avatar
i know a way to raise idle on DBW....
318_tC is offline
Old 11-01-2007, 12:53 AM
  #92
jwaggz82's Avatar
^ for some reason I really thought it could be done by the AEM management
jwaggz82 is offline
Old 11-01-2007, 01:01 AM
  #93
mikescion's Avatar
see there we go holding back on info like its a treasure LOL how ___....hmmm
Old 11-01-2007, 01:41 AM
  #94
Keeshwah's Avatar
pardon my ignorance, but why would u want to raise the idle?
Keeshwah is offline
Old 11-01-2007, 02:00 AM
  #95
mikescion's Avatar
to be a maybe bandaid for big injectors with piggy back for better idle and AFR's
Old 11-01-2007, 02:58 AM
  #96
jwaggz82's Avatar
Some people like to raise it a tad so when they shift out of gear when stopping it doesnt dip below where it should be for that second .....and stall out.
jwaggz82 is offline
Old 11-01-2007, 03:42 AM
  #97
mikescion's Avatar
so how can we raise the idle anyone know???????
Old 11-01-2007, 03:48 AM
  #98
He really isn't holding info on anything. I know how to do it with the AEM (like 318-tC) but I don't know how the OEM ecu will react when rising the idle. I might try it later but it is not very high on the "TO DO LIST".
Pito
Old 11-01-2007, 12:29 PM
  #99
jwaggz82's Avatar
^ yea the only reason why I could see ...like i said before .... is cause if you are high in the RPM's and you take it out of gear it slams below 1k and then bounces up 200rpm ..... I could see benefit if you changed it a veryyyy veryyy small amount (like 100rpm - if that is even possible I am not sure).
jwaggz82 is offline
Old 11-01-2007, 12:36 PM
  #100
318_tC's Avatar
Pito
Actually it's something different other than just on the AEM, something we figured out when we were at the shop tuning it originally. Notice, Dezod sell's it with there AEM unit now. It's made by T1
318_tC is offline
Quick Reply: ScionGT35R 476whp@19psi pics all over
