SCIONGT35R Custom Intake Manifold
As the title says this is the new custom intake manifold that we made for SCIONGT35R.
We used oval tubing along with oval velocity stacks. The runner dimensions are 2⅛ x 1¼ internally.
It also has four ⅛npt fittings on top of the plenum to connect to the MAP sensor for the e-manage, MAP sensor for the electrical boost gauge, reference line to fuel regulator and one to the Tial BOV. It also has one ¼npt fitting for the connection to the brake booster.
Runner length was made as long as it could without interfering with the firewall and to allow the Intake Manifold to be removed with the engine still in the car.
The throttle body is installed on the 90 degree aluminum elbow so that we don't have to install a silicon elbow which tend to blow off with high boost (Boost levels that we will be seeing soon).
The Plenum is design to promote intake charge speed. That is the reason why it is wider at the entrance and thiner as it reaches the runner for the 1st piston.
Thanks for looking
Pito
Thanks for looking
Pito
Originally Posted by jwaggz82
Any pics of it installed?
This is part of the new setup before parts where sent to the be Powder Coated and everything else is at the machine shop.
Pito
Originally Posted by flint_08
Confirmation. I'm hard.
Question though ... like the gentleman above said, because of the design is there much turbulence?
We also didn't wanted to have the regular rounded plenum and this design also allowed us to achieve a plenum with a higher volume.
Pito
Originally Posted by yamaha16bw
Stock throttle body? Looks like it.
I still don't know if the RX-8 throttle is a direct fit (electrically speaking) and I don't want to be hacking the firewall to install one with a cable.
Pito
Originally Posted by Whocares05050
LOVE IT!
But c'mon, lets get that fuel rail upgraded too! haha.
Originally Posted by SeanstC
nnicceee.. how much? or is not going to be mass produced?
