ScionGT35R' new numbers +500 on pump gas
Old 03-17-2008, 02:35 PM
Ronin Scion
Ace83's Avatar
nice! good numbers.. any torque graph/numbers?
Ace83 is offline
Old 03-17-2008, 02:43 PM
Music City Scions
rhythmnsmoke's Avatar
^^Nice....So, does the AEM have the ability to control the VVT-I? I believe the Hydra does, wondering if the AEM does.
I love how when the rev limit is increased on the tC, and we put the bigger turbos on, the power band NEVER falls. Pulling all the way to redline. I remember Brian said his pulled all the way to redline as well.
rhythmnsmoke is offline
Old 03-17-2008, 02:58 PM
05-RS1's Avatar
congrats on the numbers! bring back some great times too! also, i think it looks clean, dont need the RS1 lip kit
05-RS1 is offline
Old 03-17-2008, 03:01 PM
3min3m2's Avatar
Awesome....cant imagine how much cams/tb/even an intake would help, if they existed lol
Good luck, keep up the good work
3min3m2 is offline
Old 03-17-2008, 04:21 PM
Mr_Meaty's Avatar
I like how you have the company logos in the stripe! And that's the CF hood I wanted...let us know how it holds up to the heat.
But what springs do you have on? The fronts look higher then the rears.
Mr_Meaty is offline
Old 03-17-2008, 04:36 PM
Music City Scions
That's the Seibon version of that hood right? Does the Seibon one come with a rain guard? The AIT version of the same hood (which I have) comes with the rain guard.
Old 03-17-2008, 04:55 PM
ScionGT35R's Avatar
The heat it supposed to escape or dissipate thru the vent. For now I have no signs of problems due to heat. I have Tein H and it probably looks higher on the front due to the surface were the car was or the 2 gel batteries and the sound system on the back of the car. It looks even on flat surfaces!!!!!
Yes it's the Seibon one and nop it doesn't come with rain guard but no problems yet whit that either.
ScionGT35R is offline
Old 03-17-2008, 05:24 PM
Music City Scions
Why because You rarely get rain, or don't drive in the rain? I know not to get the Seibon version now, cause I would need a rain guard (well, I guess I could make my own.. ).
Old 03-17-2008, 09:26 PM
brett561tc's Avatar
it says that it does on dezods site. i think that goes for all others too. i.e. motech, dta, hks...
brett561tc is offline
Old 03-17-2008, 09:32 PM
brett561tc's Avatar
aftermarket cams already exist, and he has an intake.
Old 03-17-2008, 10:29 PM
Music City Scions
kool, kool. Like to see someone work out the VVT-I part.
Old 03-17-2008, 11:03 PM
brett561tc's Avatar
i think he will. you gotta remember that he still only has a e-manage ultimate right now. btw. whats the deal with brian's car? havent heard a peep out of him in a while. i remember something about transmission issues. i figured he would have hit up the track by now. sure would like to know how its going.
Old 03-17-2008, 11:38 PM
Mecanica_Pito's Avatar
383ft/lbs @ 7,000rpm's
Pito
Mecanica_Pito is offline
Old 03-17-2008, 11:55 PM
TCFROEZEL's Avatar
Hey pito , maybe i will hire you in for the set up of my car.
but maybe i will go supercharger.
TCFROEZEL is offline
Old 03-17-2008, 11:59 PM
Music City Scions
It's done, he just has to get time to get down to Houston to pick it up. He has been real busy, moved twice, club administration stuff...just a lot on his plate. 542whp was the final numbers on that one if I recall. Transmission got worked out as well. I believe he had the tranny swapped out and sourced out a 2005 Transmission. Funny thing is, that's what I ended up having in ours too, an 05 tranny.
I think on like 13 psi it was around 345whp (low compression), and I forget what PSI the 542whp numbers where made. Didn't want to go above that though, as it still has a stock intake mani. His dyno graph pulls all the way to redline without falling toward the end as well.
DAMN can't wait to see my graph do that...lol.
Old 03-18-2008, 12:28 AM
Ronin Scion
Ace83's Avatar
Pito
not bad, revving at 7.5k you got more HP on the top end
Ace83 is offline
Old 03-20-2008, 02:58 AM
krazylowgsx's Avatar
Pito
i bet his top end power is sick!!!!! i figured the car would have produced more torque than that.
krazylowgsx is offline
Old 03-20-2008, 09:25 AM
Pito
At the rpm,s were the engine is supposed to make peak torque numbers the engine is only pushing 18psi! The 23psi is a boost spike towards the end of the run!.
Pito
Old 03-23-2008, 05:39 PM
Bad news guys ...
A couple of days ago SCIONGT35R installed some BFGoodrich's g-Force™ T/A® Drag Radial on the stock 17" wheels to go and try launching with them on the local 1/8th mile track. Tried a couple of times with uncontrollable wheel spin even at 14 psi!
We called a friend who is the official team driver and while making the burnout at the track the engine died! The engine crankshaft locked up. After tearing down the engine it was found that rod #3 bearings where the ones that caused the locking of the crankshaft. The crankshaft is not good so we are going to find a new stock one to install.
The rest of the rod bearings are completely OK and so are the main bearings. The car didn't had an oil pressure gauge installed so we don't know if it was a problem with the oil pressure or if it was caused by anything else.
Pito
Old 03-23-2008, 05:46 PM
etsnet's Avatar
That sucks! Believe me I know.lol You think it could have had anything to do with the last problem? What bearing are you using?
etsnet is offline
Quick Reply: ScionGT35R' new numbers +500 on pump gas
