SERIOUS PROBLEM PLEASE HELP! lol
Old 05-02-2007, 05:27 AM
Garage1217's Avatar
Ah good then your set there Sounds like JE..? They have the 8.5:1 in stock.. most others are 9:1
Garage1217 is offline
Old 05-02-2007, 12:48 PM
Brett's Avatar
sounds to me like a coupler came loose on some of your piping. check all your couplers.
Brett is offline
Old 05-02-2007, 12:57 PM
318_tC's Avatar
Compression Check and Leak Down Test
1. When you turn the ignition on do you hear the fuel punp?
2. Have you check all your intercooler pipes and couplers make sure its not loose/cut/or a hole any where?
3. Vaccum leak, check all ur vaccum sources
4. Check ur oil, does it seem like you hvae lost alot of oil?
5. Try stock injectors, see if you get anything you could of had ur injectors fail
318_tC is offline
Old 05-02-2007, 01:13 PM
ProshopXB's Avatar
Vac leak for 100...Alex
Had the same thing happen to me, thought my MAF took a dump, but it ended up being a factory vac line came undone...
ProshopXB is offline
Old 05-02-2007, 03:29 PM
Dyltone's Avatar
Originally Posted by DaGreat1
I just put new piston and rods in there 8:5:1 i dont think its that...there BRAND new
Doesn't matter if they are new or not, if you were running a bad tune, the best pistons in the world won't hold up. Please, just get the leak down test done. This will tell you if it's serious or stupid problem and it only takes 10 minutes to do.
Dyltone is offline
Old 05-02-2007, 04:22 PM
krdshrk's Avatar
He's tuned though - it's a good tune. Ripp did it.
krdshrk is offline
Old 05-03-2007, 12:11 AM
Dyltone's Avatar
I'm not bad mouthing the tune specifically, but a failed component (injector, boost controller, wastegate spring, pressure sensor, o2 sensor, ignition sensor, loose wire on emanage) or a emanage glitch could cause the motor to run out of tune after it was tuned.
I'm sorry to keep asking for this, but get a leak down test, if it comes back good, then it shouldn't be a serious problem. If it comes back bad, well... that's bad.
Dyltone is offline
Old 05-03-2007, 01:11 AM
DaGreat1's Avatar
yea im do that thanks everyone for the help
DaGreat1 is offline
Dmmcclair
08-13-2015 07:14 PM
my06tc
06-25-2015 12:18 AM
sciontcguy15912
04-04-2015 03:56 AM
TheRedBox
26
11-23-2003 09:09 AM
smilygo
10-01-2003 07:03 AM
Quick Reply: SERIOUS PROBLEM PLEASE HELP! lol
