Slapped on a turbo.. now what? AEM EMS vs. Rods + Pistons
#61
Originally Posted by paul_dezod
Originally Posted by TCFROEZEL
DID you blow your engine with the e-manage ?
you are talking like it was the e-manage FAULT on your engine.
#62
My thing is that if you get the EMS first, you pay for tune, then you build, up the boost, and you have to get tuned again, and an EMS tune will cost more then a piggyback tune.
Or, you could build the block on your existing tune and when you finally get the EMS, get it tuned and your done.
#63
This is with the Ultimates AND Blues. The way the e-mangles retard timing is by skewing the voltage to the coilpacks. Unlike the FIC, which acutally alters the cam and crank signals like the EMS.......The skewing of the voltage in an more aggressive retard or advance mode makes the packs go pop. The voltage staggers out of it's stable range and makes the pack go bye bye.
#64
I guess my question would be then, going from a stock motor to a built one (rods/pistons), what causes the emanage to now start blowing coil packs, when all you changed when it comes to the motor itself, are rods and pistons?
I have not experienced any blown coil packs in the near 2 years I've been running on the blue box. So, if I go built motor, what parameters will now confilict with the Emanage that didn't when the motor was stock, to cause it to screw with the coil packs?
like i said before. the e-manage is only good for mild boost aplications. trying to push it any farther than that will only result in dissapointment.
as for the question about me blowing my motor. no, the motor is fine. in fact its pretty damn stout. i've had compression tests done recently, and they showed that the engine was tip top. bout the only thing strickler ever did right.
#67
Kool.
Just for the record, I spike to 13 and settles on 11.5-12 PSI. Add some Race gas and I'll run 14 PSI.
By the way, what gave you the indication that your coil pack went bad?
#68
Originally Posted by Mr_Meaty
Well, that settles it! All you need is a turbo setup that gives you 450whp at 11psi and youre better off with a built motor then the AEM EMS
Big ___ turbo is the solution then....
#70
#72
This is actually a great discussion. I'm in a similar boat since I just got a bonus and can really afford only 1 of the 2 options. Instead of waiting another year to potentially get both, I wanted to do one or the other right now while I had available funds. I'm still up in the air though, but this has been helpful so far...
#73
