smoke coming out of my hood
so i have a 2005 scion tc with a zpi stage 0 kit. i noticed to that my breater on the top of the engine has smoke coming out of it when i drive it a little bit.i havent been it boost for a while due to much slipping clutch. please help.
i had a similar problem when i was open dump but it went away when i put my exhaust back on obviously lol but the thing is, could there still be an issue of piston rings cracking?
I've yet to do a compression test.
this sounds crazy but yea open dump caused my turbo to leak oil like crazy lol - what happens is when the pressure in the chra oil flow is higher than the pressure on the turbine side it allows oil to pass by the piston ring seal - so putting a lil more back pressure on the exhaust and walla its gone lol
hmmm makes somewhat sense, that is what i had assume that the loss in back pressure had caused it but at first i started buggin because i was like OMGZ everything just went boom but nope
yay lol
yay lol
O yea it was a tnetics turbo too lol you might have the same issue - our high egt seems to create an issue for this turbo do to the oil flow design but apparently the water cooled chra will correct this - hopefully so because i have a tnetics turbo 50 trim thats sitting on my desk with water chra
