SNEAK PEAK AT ONE SWEET NEW TURBO KIT COMING OUT SOON!
As many of you have noticed, I have disappeared from the FI section for awhile as I have been working with one of the best tuner shops around, Intensepower.com Intense has been around for many years building totally insane cars, from monster 1000+ hp supras to triple rotor rx7’s, these guys have it covered. They recently moved into a HUGE facility and fab center which is very impressive. The building is coming along great and is changing daily into one impressive new shop! The welders and fab guys have countless years of knowledge behind them which is why the best of the best go to Intense! You never know who you will find having a car done by the Intensepower crew, from Sports players to famous drag racers. They all trust these guys!
I started talking to Intense this past November as they were starting to design mid to high end kits for many applications and they were highly interested in our Scion tC’s. Ideas were thrown around and talked about and then a plan was made. The plan was simple, build the best available. The guys at Intense thought it would be best to build the high end kit first, and then base street kits off of the high end kit. After all, trying to build a high end kit from a base kit is not the best way to do it...
The setup on my car was completed last week in time for Nopi nationals in which I am proud to say, my tC took home a sweet 1st place in the Toyota, Lexus, Scion custom category! The kit made a HUGE impression on the spectators and even other tuning companies. Tuning is still being completed on my tC and dyno results will be posted soon. At this time I am currently running 5.8 psi for testing and data logging and it totally SHREDS on my old supercharger setup at 10 psi that made 252whp. I mean wipes the floor with it so I cannot wait to see numbers, especially after the engine build that is soon to come which will let me take advantage of such a wicked setup! For now the setup will be tuned to 8-10 psi.
The fab work on this setup is simply beautiful and a work of art. The header in person is amazing. I really have to give props to the hard workers and fab guys at Intense! They threw down countless hours and sleepless nights designing and building this setup. The setup I am running is set to be the high end kit they will offer. It supports 500+whp with engine internals and is NOT laggy. Spool is simply vicious / hits hard. The high end kit is the PERFECT choice for guys ready to build, or are currently building there engines.
Early specs on the high end kit include….
- GT3076R ball bearing turbo or larger “Your choice”
- Custom stainless top mount header that works with the Kaminari drop vent hood.
- Tial 44mm Wastegate w/open dump under tranny, does not blacken your engine bay!
- New released HKS Bov valve or Tial Bov… Still in discussion.
- 3” stainless downpipe
- Drop in 550cc or greater injectors
- Emanage Ultimate with harness & map sensor “this setup WILL tune partial throttle perfectly without the ecm fighting the emanage! Already tested and proven”
- All aluminum intercooler pipes that are made correctly, no using silicone couplers to make angles and connections. The pipes fit as they should! All pipes are bead rolled so you do not have pipes blowing off on you.
- Large front mount intercooler “exact size TBA”
- K&N xtreme filter with bracket mount top
- All high quality silicone couplers with t-bolts
- High end waterlines and oil feed lines will be included “kit oil feed line is not like the one on my car currently and pictured, that was a last minute item as the right fittings were not available.
More info, specs and prices will follow in the next few weeks as Intense wants to get this right and make you guys happy! I can say without a doubt, this is the best designed and looking setup I have yet to see period. There are a lot of nice kits on the market, this one just jumps the game to the next level! I do hope you all take a real close look at Intense and the new kits. You can also check them out at www.intensescion.com
Originally Posted by blackonblacktc
holy lord that looks great, those welds are immaculate.
subscribed
subscribed
Originally Posted by zer0
I love how tC turbo kits in 07 are using big turbos in kits. Just goes to show the 2AZ is a monster that can make some power on stock block.
Numbers?
PS....Intense is AWESOME by the way! I've been keeping them as a source for my 350Z needs.
