Snow Performance Boost Cooler
I was wondering what you guys thought of this product:
http://store.summitracing.com/partde...5&autoview=sku
or
it says that its used in a roots style s/c ...which the t/c doesnt have. What do you guys think of it? Is there a better one?
or
Team No Limitz
talk to turbocustomz....he was rockin that in his tC for a while...I dont know if he is still using the water/meth kit though, it has been a while that he has had it on
We spoke in an IM but i thought I'd throw it out on here as well. The Snow Performance Kit is one of the nicest kits I've seen/used on the market. It comes with absolutly everything you could need to hook it up and some decent directions. Its definatly worth every penny.
I was told by TurboCustomz that I should get this MAF kit:
(which is the stageII kit)
Originally Posted by jwaggz82
does anybody know which injector size to get? ....you get a choice of 2 I think....?!?
http://store.summitracing.com/instru...%2D20001%2Epdf
Question about that and the one from Ripp...
Is refilling necessary? If so, how often? Never really read much into the injection systems :p If it will support more power for that kind of money and easy setup, I may just run one ~~
Garage1217 said that he likes this one better then the snow one....does anybody feel the same?
This one:
http://www.coolingmist.com/detailmain.aspx?pid=01250TBF
...... what do ya think of the product and company??
This one:
Already spoke with them, and this is what they said:
Hello Craig,
I would recommend the Stage 2 Boost Cooler™ kit that reads manifold boost pressure to proportionally inject more or less water-methanol. This is proven to be the best way to get the most horsepower over the widest range of conditions. It is also the best kit for a daily driver, as you will be injecting the maximum possible over the widest range of conditions. With the Stage 1, you need to inject the minimum amount of fluid so that it won’t bog at whatever rpm and boost you start at – everything beyond that will be injecting less than optimal. The Stage 2 is also very easy to adjust if you change other things in your engine setup in the future.
The MAF based kits are usually used on positive displacement superchargers like Eatons, whereas your TRD/Vortech supercharger is centrifugal, and the standard #20010 kit works better with that type of forced induction.
The cooling effect will definitely help your performance and consistency, especially without an intercooler. Temperature drops of 60 to 100 degrees F are not uncommon. The other huge benefit to running water methanol is octane improvement. With 91 pump gas and 50/50 water-methanol, it is roughly equivalent to 116 race gas. This allows you a number of options. You can run with cheaper low grade gas, you can advance the ignition timing for more performance and you can increase the boost, or some combination of all three. You will likely be able to slightly lean the fuel delivery for more performance as well.
At your performance level now, I would suggest a 225 nozzle, and I would include a 375 nozzle for your future setup.
Hope this answers your questions – let me know if you have more or are ready to order.
Sincerely,
Greg Dunn
Sales Director
Sincerely,
Greg Dunn
Sales Director
This one:
This one:
On the same note, I havent heard anything bad about the Coolingmist setup either.
Charles
