soon to get turbo....
The first thing you need to do is sit down and set a project goal. A good baseline for starting out, especially if this is the first time being boosted, would be mid 200's for horsepower. Get a feel for the system and how it works. Once everything is in place and you feel comfortable, you can then progressively add on and make what you have more powerful. Don't just dive in to something blind.
Easy and early preparation items you can get:
1.) Boost/Vac gauge: Won't help you until you actually get your forced induction system installed, but it will definately be worthwhile to have ready to go.
2.) Wideband AFR gauge: Definately a great tool for monitoring and tuning.
3a.) Oil Pressure gauge: Good to have to monitor for possible leaks or low level indicators (the dummy light for low oil is too late of an indication) or Excessive oil pressure may indicate a blocked filter or blocked oil gallery.
3b.) Oil Temperature gauge: I don't really have much information on Oil Temperature and why exactly it's important, but I do know that excessive oil temperature can decrease performance in the long run. Temperature thresholds are determined by the viscocity of the oil uesed.
3c.) EGT gauge: This will help you to see if you're running rich or lean. Using this in conjunction with an AFR gauge will help you tune your fuel management. There is an optimal temperature for the combustion. In general the cooler the exhaust gas is, the richer the fuel mixture, the hotter the exhaust gas is, the leaner the fuel mixture.
4.) New Spark Plugs: Generally you can get a set that are one step colder but some people go and get two steps colder, but they are usually pushing quite a bit more horsepower.
Just a list for starters. I'm pretty sure others will chime in and suggest more.
Regards,
Benjamin
Regards,
Benjamin
If you know FOR A FACT that you will be turboing soon, your best first mod would be a good 2.5" exhasut system. It's going to be GREAT for when you turbo. Don't worry about an S pipe..if you get a dezod kit it comes with a 2.5" down pipe and 2.5" s pipe. :-)
Regards,
Benjamin
Regards,
Benjamin
3" exhaust on a low boost application can actually be detrimental to hp/tq gain.
Edit: I don't actually know for this car... I haven't looked into forced induction/resonance/timing/back pressure for it yet... just happen to be browsing by.
