Spearco Water Injection System (Universal Kit)
Team No Limitz
Originally Posted by kytc
I would like to see a s/c go this route. I think it's an excellent kit and would work awesome. I might even add one to mine later this year to make my intake temps freezing instead of cold, lol.
the average use with the trd flash will get a few extra hp. Someone with management will get 10+hp .... the water injection keeps your numbers consistant by getting rid of excess heat. The more hp you have to start with the better results you will get w/ this product.
I know this thread is old. But I want to buy simplyscions setup so I want to have some questions answered.
I have researched and now understand how it works. But, I could use this as my cooling instead of an intercooler and run 12 psi safely, correct?
I could have it set to only run when above a certain psi, correct?
I run 9.5 PSI safely now, so the way I see it, if I can set the boost level, I can have it on constantly and only spray above say 9 psi for daily driving. That would be VERY rare for me.
Then at the track have it set to run constant a a run.
Is my thinking correct? or is there something else I would need?
I would wait to install this untill I could have RIPP do this, an emanage install and cams, and 12-14PSI. Just figured I would buy slowly to keep funds rolling.
Thanks to anyone that can help.
Well some people do say that water/injection can make up for a lack of intercooler but to be honest I've never seen data proving it. In regards to your questions yes you can set it to run only above a certain PSI and that is full adjustable from the drivers seat (assuming you mount the controller somewhere near by) for when you are at the track to lower the PSI level at which it activates.
Thank you miaplaya.
So do you think it would be safe to run 12psi on the supercharger with the spearco meth kit with no intercooler?
Its cool. Thanks tho. I guess ICENINE is doing it. I will only ever run that high of boost at the track.
I barely ever hit 9.5 PSI now. I rarely run out the gears.
I bought the spearco kit off Simply Scion. Now I need the GM map sensor and a resevoir!
Use the windshield washer tank... It's like 1 gallon and is designed to hold water and methanol. I've got a 2 quart tank on mine waer injection system -but it's getting old having to fill it up every week because of where I put the tank (under the battery). Windshield washer tank would be like once a month refill -maybe two and it's real easy to refill -even with the engine hot and you can check the level with the cap-mounted dip-stick.
If you need a progressive controller for the meth look at devil's own on-line that's the one I use on my system.
That write up is perfect. I wasnt sure if I could do this myself, but now I know I can. Maybe I will install it now, without tunning or turning up the boost. I can just let it sit and then everything else will come in stages.
Originally Posted by zer0
Anyway the Greddy Pressure sensor could be used instead of the GM 3Bar?
I have been checking prices and with the map sensor and the power supply and all this and that, I am just going to sell my mechanical boost gauage and get an electrical one. It will be much simpler for me.
I also highly recommend using the washer tank res. It is 4 litters large and I fill up once a month if that. I do drive conservatively though.
If you have any question on the install don't hesitate to ask...
That is a good write up. I will deffinetly be asking. I might install it when I get it this month.
Only thing I dont like about using the washer tank is not being able to use my wiper fluid.
The Spearco kit comes with a plug that you use is you were using a seperate tank. I am going to drill the 22mm hole next to the exiting outlet so I can run both.
I'll let you know what I find out
