stage 0 installed
stage 0 installed
Ok my stage 0 kit went in yesterday. The engine putters once I get past about 3500rpm like the stock fuel injectors can not keep up with the flow from the turbo. The boost gauge I received was broken so I am getting another one overnighted to me today so that I can make sure all the vacume lines are ok and I am not running more than 6psi. What do you think my issue is? I am 99% sure all the vacume lines are correct and the 6psi spring is indeed in the waiste gate. Also after the blow off noise there is a strange are wooshing noise for a second I am not sure if this is the waist gate dumping or somethhing to do with the blow off valve. I am the first one around here turboed so none of us know the answers to how things should be sounding etc...
ok kool, is it common to have a rough idle with the stage 0 and intercooler upgrade?, like the car would die once in a while if let go of the gas abruptly, i kno its because i'm leaning out but are others having this same issue?
Do you have fuel management added? The Stage 0 will work fine without fuel management, but when you start adding upgrades, it's better to play it safe by adding fuel management.
u sure its burning oil? i know w/ my greddy kit it smelled like something was burning but was told it was the manifold cuz of the coating. that went away in time. id say check ur oil before u start ur car every time to be sure
the stock injectors should be good.....did you change our your spark plugs? at wot, the open dump from the wastegate sounds like a throaty flapping sound.....thats normal.....i didn' run fuel management for 6 months, and have had no problems whatsoever......may smell like burning oil cause half of your pipes could have oil on them, and you just didnt clean them off....if not, see if you have an oil leak by driving down the street and seeing if you leave droplets, or the night before,put a piece of cardboard under you car and see if anything leaks from there.....good luck
jay jay you wont get past 0 psi when you're not in gear.
now your bov should still go off. make sure your vac line is t'd into the vac line of the throttle body.
and to the op please post pictures of the install.
TheRedBox
31
12-02-2003 04:53 PM
