View Poll Results: Who thinks I am an idiot for posting this thread?
I am and idiot
35
38.89%
I am not an idiot
55
61.11%
Voters: 90. You may not vote on this poll
Stock Block/Stock Head +7PSI, E85, NO TUNE+Wire Tuck+ABS Relocate (01/17/11)
Old 03-07-2010, 03:50 PM
  #321
akeemc90's Avatar
Originally Posted by DezodDon
LOL we are fresh out of reliable
akeemc90 is offline
Old 03-07-2010, 04:01 PM
  #322
ElevationTC's Avatar
cracked ringlands = det
You may not of notice it yet.. But in time it would have failed. Ive pulled other motors out to see cracked ringlands with no issues.
Hell the car even put down 275 to the wheels (b16a2) ran fine.. we pulled it part to sleeve the block and seen that and were like wtf!
ElevationTC is offline
Old 03-08-2010, 05:24 PM
  #323
johnhawkins's Avatar
Any scoring would be noticable right? When rubbing with a finger I dont feel anything.
johnhawkins is offline
Old 03-08-2010, 05:56 PM
  #324
DezodDon's Avatar
Originally Posted by johnhawkins
What is this? My old 05 block I bought from Dezod didnt include this? Clearly not a block guard...does it help the flow of the coolant?
Did you buy a stock engine from us? I'm confused. Either way that coolant jacket sleeve was an 07+ addition to the engine design only. It was never in the 05-06 engine, they did this to improve coolant around the cylinders so that they could run a lighter engine oil and absorb the additional heat created by friction from the piston to wall clearance. They were trying to reduce friction.
So yesterday Itook apart the block and pretty much threw the rods/pistons in my back seat on the floor (winter car)....went to bring them in the garage today and noticed ALL 4 ringlands cracked.....all on the same side on the piston. Now one could blame on running 6psi with no tune, hard driving. Any way over reving could cause this? (ex. Dropping from 4th to 2nd gear on accident) Or is it just coincidence that they are all cracked on the same side from rolling around on the floor of my car for a day? PS There was no scoring of the cylinder walls.
Cracked ring lands comes as a result of too much heat in a cylinder whether it be lean, too high an EGT meaning not enough timing but this is probably not the case with your engine. Pistons designed for NA purposes have thinner ring lands to reduce the mass of the piston. They also have steel struts cast into the aluminum piston like a rib cage. These hold the piston to a nominal size. Piston to wall clearance on a stock engine with cast pistons is smaller as a result. Forged pistons do not have struts cast in because they are not cast, they are hammered from a chunk of aluminum. As a result of this and different alloys forged pistons expand and require a decent piston to wall clearance in order to not scuff.
What I am getting at here is that when you boost a NA engine with stock internals you are applying more heat. More power = more heat in the engine. These parts expand more than they were designed to and as a result you get increased wear on the thrust side of the piston. Ring gaps butt together, ring lands expand due to the increased heat and when the conditions for detonation are correct the resulting force of detonation will be transferred through the piston and crack the ring land. Usually on the thrust side as that is the one being forced down.
If you are lucky they stay in their place you just lose a little compression and may experience some smoke. If you are not lucky then pieces come loose and rattle and get pounded around inside that cylinder and damage the combustion chamber, most times after that the head is useless because even if you clean up the damage if there are areas that are pitted they tend to act as stress risers and lead to cracks or detonation from hot spots in the chamber disrupting the proper propagation of the flame front during combustion.
Scoring you would want to worry about would be anything you can catch a finger nail on. Most scoring like that will come out with a good hone. If after a hone it's still there then you will need to bore the cylinder and then re-hone.
DezodDon is offline
Old 03-08-2010, 08:39 PM
  #325
Thanks Don...Deff some good info there....I dont feel ANYHTING when I rub the cylinder walls so there is deff no scoring...and you can still clearly see the original cross hatch...I purchased a 05 block from Dezod West a while ago with the help of Paul that I was going to use but decided against it. Any differences in using apposed to not using the coolant flow plastic piece????
Old 03-08-2010, 09:21 PM
  #326
DezodDon's Avatar
Not sure if the block will allow for use of the sleeve. Check it out and see.
DezodDon is offline
Old 03-13-2010, 12:32 AM
  #327
Old 03-13-2010, 12:33 AM
  #328
B_Real45's Avatar
you should make a shroud. the fans will work much more efficiently.
B_Real45 is offline
Old 03-13-2010, 12:52 AM
  #329
I was thining bout it what you think - Push the Air out of the engine bay or in?
Old 03-13-2010, 12:54 AM
  #330
B_Real45's Avatar
With a shroud a pull might be better.
B_Real45 is offline
Old 03-13-2010, 12:59 AM
  #331
I always forget push is puching the air out and pull is pulling the air from outside in? Wouldnt it be bad to put a shroud on the outside of the radiator how the fans are mounted now due to the fact that when in motion not much air would be going thru the rad?
Old 03-13-2010, 01:01 AM
  #332
B_Real45's Avatar
no you want the fans and shroud on the other side... engine side. air pulled in from outside.
B_Real45 is offline
Old 03-13-2010, 01:10 AM
  #333
No I deff need them mounted on the outside of the rad due to clearance issues.
Old 03-13-2010, 01:12 AM
  #334
B_Real45's Avatar
Ah I see.. is it only on one side of the radiator that you need clearance? If so, you can do a push and a pull.. one on each side.
Or you can get a custom half-sized radiator made.
B_Real45 is offline
Old 03-13-2010, 01:22 AM
  #335
Yea I might just do one on either side...to switch the motors direction just switch the two wires?
Old 03-13-2010, 01:25 AM
  #336
B_Real45's Avatar
Only if they're designed that way. Some fans cannot have their polarity reversed.
B_Real45 is offline
Old 03-13-2010, 12:24 PM
  #337
Yea I dont think the kind I have can be reversed...so I have to take the fans off the rad now and unbolt the fan and reverse the direction........so that mean I have to buy 2 more sets of mouting kits....
Old 03-13-2010, 12:37 PM
  #338
B_Real45's Avatar
Mounting kits can be purchased almost anywhere. Try your local auto parts stores first.
B_Real45 is offline
Old 03-13-2010, 04:04 PM
  #339
trd07tc's Avatar
civic radiator FTW.
btw when I bought my slim fan a WHILE ago I think i remember the manual saying if u want to reserve the fan wire it in backwards
trd07tc is offline
Old 03-13-2010, 05:36 PM
  #340
I wasthinkin a half rad but then hav to worry about new hoses
Quick Reply: Stock Block/Stock Head +7PSI, E85, NO TUNE+Wire Tuck+ABS Relocate (01/17/11)
