View Poll Results: Who thinks I am an idiot for posting this thread?
I am and idiot
35
38.89%
I am not an idiot
55
61.11%
Voters: 90. You may not vote on this poll
Stock Block/Stock Head +7PSI, E85, NO TUNE+Wire Tuck+ABS Relocate (01/17/11)
Old 12-02-2009, 10:26 PM
  #161
SoFloTC's Avatar
ok someone explain to me exactly what happens when u take a turn im kinda confused....
SoFloTC is offline
Old 12-02-2009, 10:30 PM
  #162
ElevationTC's Avatar
OK, imagine this.. Basically your tires are welded together via ur diff.. when u make a turn now, one wheel spins faster then the other,
welded diff means BOTH ur tires spin the same speed all the time!
ElevationTC is offline
Old 12-02-2009, 10:31 PM
  #163
Domo's Avatar
good read
Domo is offline
Old 12-02-2009, 10:32 PM
  #164
http://www.youtube.com/watch?v=Cz6Zu...eature=related
Old 12-02-2009, 10:35 PM
  #165
coryjames's Avatar
when you turn your tires are at two different radius es es es.... so the outer needs to cover more ground to make the turn then the inner. this is the reason behind needing a differential to not let the inner or outer tire bind up the tire with more traction will hold the road the other will slip on a fwd car its usually the inner tire so it squeeks or chirps. a lsd still has the option to differentiate unless on the power thus locking the mechanizim inside then locking the two axles together. a lsd allows some slip but not much when on the power a full locker detroit style wont alow and slip
spools are what you will find on most drag cars and even on top fuel dragsters when you launch you will launch straighter then you ever have before. since one cant go faster then the other you go straight.
now when auto crossingg you will be riding with most the traction on the outside wheel it will slip the inner but wont alow your rpms to go up without spinning the outer wheel so you get thrown through the corner hard now parking will be an issue if your trying to be sneaky lol
coryjames is offline
Old 12-02-2009, 10:40 PM
  #166
SoFloTC's Avatar
lol.. is the welded diff making noises? and what would be bad about having both tires spin equally on a turn? i mean i see what u mean but why is that bad
SoFloTC is offline
Old 12-02-2009, 10:45 PM
  #167
Ill tell u what chad, when i have your trans apart tomrmorw well get it welded..
and well find out!
  #168
SoFloTC's Avatar
damn.. maybe ill just stick to an LSD lol
SoFloTC is offline
Old 12-02-2009, 10:46 PM
  #169
SoFloTC's Avatar
and well find out!
haha um no!
SoFloTC is offline
Old 12-02-2009, 10:59 PM
  #170
coryjames's Avatar
do it do it if you do it its a easy you can do it till you get a lsd then put the lsd in it wont afect the lsd cause its a whole new carrier assembly
Old 12-02-2009, 11:03 PM
  #171
he has two diffs anyways! he bought a spare trans..
i say u do it baller chad! 3rd gear two wheel burnouts.. then we can out lambo whopping!
Old 12-02-2009, 11:06 PM
  #172
SoFloTC's Avatar
lmao wtf guys.. how much would it cost to weld a diff for ____ n giggles anyway
SoFloTC is offline
Old 12-02-2009, 11:08 PM
  #173
id guess around 25.00 to 50.00
Old 12-02-2009, 11:10 PM
  #174
SoFloTC's Avatar
thats it.... wtf lol i mean id be kinda scared putting in the car. and mike if we throw the welded diff in then u might have to stay longer incase i dont like it to take it out lol
SoFloTC is offline
Old 12-02-2009, 11:20 PM
  #175
Uh, i think not lol.. if you decide to put it in.. your stuck with it for a while..
Old 12-02-2009, 11:25 PM
  #176
SoFloTC's Avatar
^def not doing it then lmao
SoFloTC is offline
Old 12-02-2009, 11:27 PM
  #177
less work for meh!
i mean as it is i have to rebuild your trans tommrow lol!
i cant wait for tommrow night! lets rent a lambo and go drifting or something!
Old 12-02-2009, 11:34 PM
  #178
SoFloTC's Avatar
what the hell is 2morrow night? lol
SoFloTC is offline
Old 12-02-2009, 11:42 PM
  #179
miami glow sonnn
Old 12-02-2009, 11:43 PM
  #180
SoFloTC's Avatar
LOL no thats dec. 18th son! daygloooo club space
SoFloTC is offline
Quick Reply: Stock Block/Stock Head +7PSI, E85, NO TUNE+Wire Tuck+ABS Relocate (01/17/11)
