Stock Clutch Support
stock clutch should hold around 250whp.. with around same tq... but you are pushing it already...it would wear alot faster cause of the stock rating , is suppose to last the life of the car.. with out abuse... or mods...
Any clutch should last 100k or more if it is used in its proper application. If you start dumping more power, racing or driving it badly then it will of course die early, but any decent stock clutch should last 100k or more easilly
Team No Limitz
guys, first of all clutches arent rated on how much HP you make...its TQ that will determine when a clutch will fail...the stock clutch will definitely start to slip once you hit that 250 ft/lbs tq...My stock clutch would slip slightly even at 200 ft lbs after a few hard runs
Everything past the rods are affected by torque when you are talking about damage or lifespan. Torque is the only force an engine creates. HP is a calculation of how that tq is applied over time. So it is correct that tq is what damages the clutch. The pistons and rods are subjected to compressive and tension forces due to the combustion process, which is then converted to tq at the crank.
well hey guys last night i ran at the track once and guess what??? my clutch fried with the first run lol but im sprayin 75 wetshot so that sudden kick of torque ( from 140 to 260 in a sec lol) fried my clutch and now i cant spray till i buy a new one. my clutch slips as soon as i spray i go no where i stay in the same place revving up lol
reagan9000
01-28-2015 06:20 PM
JM Auto Racing
12-19-2014 06:36 PM
darkshadowofxdeath
12-03-2014 06:59 PM
