supercharger!!!!
supercharger!!!!
sup every1 just to let you know... about our trd sc.. it was never said on trd anywhere but this should be common sense
http://www.vortechsuperchargers.com/...s/racefile.pdf
That was one that kind of stood out to me.
7. BURNOUT BOX
Extreme care must be exercised in the burnout box.
If your vehicle is traction limited (because you have
too much horsepower for your suspension), you may
experience a supercharger failure. Traction loss can
cause the engine and supercharger to be rapidly
accelerated and decelerated as well as overspun,
resulting in a premature failure of one or both. Listed
below are some precautions that must be observed:
• The engine rpm should not and does not need to
exceed 4500 rpm in the burnout box (use rev
limiter).
• The burnout should only be done in one gear. Do
not start in first gear and shift into second. Start
in second gear and hold a steady rpm.
• You need to slowly accelerate and decelerate the
engine during the burnout. Do not stab the throttle
and let off quick. Rapid acceleration followed by
rapid deceleration may cause a supercharger
failure.
• Do not "modulate" the throttle up and down while
heating the tires.
7. BURNOUT BOX
limiter).
failure.
heating the tires.
Re: supercharger!!!!
heating the tires.
heating the tires.
That's how you keep from bouncing off Redline....
you are a few days late. this was already posted by garage in his trd s/c breakdown and rant.
https://www.scionlife.com/forums/vie...asc&&start=120
rain7905643
06-13-2018 05:29 AM
