Supercharger help plz
Hey guy i recently bought a used sc an not all piece came with it so im still buying pieces
I had this question about the oil return line does that return back to the oil pan or does go somewhere else i knw its kinda of a dumb question but im kinda new at this oh an was wondering if running it without a reflash ecu but having a unichip thats tune with the sc map will affect anything
The oil return line goes only from the s/c to the oil pan thats it. as for running the supercharger with just unichip i think it should be fine if tuned to the s/c map if i am wrong someone else chime in.
Oh ok so does that mean i tapped my oil pan twice
An wanted to ask i have plan on building my motor an wanted to knw whAt kind of compression do you guy suggest from what i read i said a 9to 5 should do but i talk to a friend of mine he has a si an he said i should get a 10 to 1 what do you guys suggest
This:
https://www.scionlife.com/forums/sho...d.php?t=112896
And these:
https://www.scionlife.com/forums/ann...hp?f=1645&a=19
Should help you.
Yes, the return line is meant to go back into the oil pan that was supplied as part of the TRD supercharger kit.
And these:
Should help you.
Yes, the oil return line goes into a tapped fitting at the front of your oil pan. As for the piggyback, I've used the AEM FIC and the emanage ultimate with great success for two different setups. For an entry level piggyback, I'll go as far as saying the FIC is as good as it gets for the price.
kidbarillas i think u should be ok using a high temp oil hose line with good clamps on it i mean the trd sc return line hose is metal in the center and both ends are rubber hose made just make sure it wont hit anything then you should be good also i rec. use aem fic or greddy ult. instead of unichip im flashed with the trd map right and runnning greddy eman. but i think you ll be fine tuning it with out the trd map on aem fic or greddy eman. ult. all the turbo guys do it.. so y not.
AZguy are you running 14psi right now? if so what sized belt and brand are you using. and also is your shaft mod.?
I am running the 55mm pulley but I was seeing peaks of 14 psi on the dyno. I do have the upgraded shaft, new bearings and greased pulley side.
Here is the link for the upgraded shaft.
https://www.scionlife.com/forums/sho...d.php?t=152018
It is a group buy so get in soon. We need like 2 more people before they get made and sent out.
If I'm goin to get stage2 cams but run a 9.5 pulley do I need bigger injectors???
I am here: http://tapatalk.com/map.php?3vfili
rain7905643
06-13-2018 05:29 AM
