supercharger issues... oil leak and burn, running rich...
#202
Originally Posted by aen
if your car is running ok check valve seals, if valve seals are broken oil could leak down into the cylinder and burn up through the exhaust
reni made me post this.
#205
Originally Posted by hunterUnknown
hahah...
ill definitely check into it tomorrow morning if i can figure it out fast enough. need the engine to be cool after all.. haha ive had enough burning experiences
#213
scion/toyota called. they'll be giving me further instruction later. in the mean time the dealership says i should check my pcv valve. i somehow doubt its going to be that simple but hey what do i know
#214
#215
actually, pcv valve with alot of oil means:
a: your seals are broken and oil is going through the cylidndar head
b: your piston rings are blown and fuel is shooting back past the piston into oil and creating blowby
c: all above and more
#217
#219
oh, ardie. i was thinking about how our cars are setup...i'm not sure if you will be able to see the seals.
you might want to get the valve springs off. and that involves filling the cylinderwith air and compressing the spring.
if you want to actually do all that i can tell you eactly how but try and just see if you can do a visual check, maybe a seal is sitting weird and you can see it or something.
