supercharger issues... oil leak and burn, running rich...
Old 08-17-2008, 07:54 AM
  #221
Mr_Meaty's Avatar
what's the pcv valve?
Mr_Meaty is offline
Old 08-17-2008, 07:21 PM
  #222
missReni's Avatar
If you need any help, you know where I'm at.
missReni is offline
Old 08-19-2008, 04:40 PM
  #223
hunterUnknown's Avatar
well i got the pcv valve... just gotta install it. positive i have to take off the valve cover?
its a little checkvalve. closes under high pressure? opens under low pressure? correct me if im wrong aen
hunterUnknown is offline
Old 08-19-2008, 04:43 PM
  #224
aen
aen's Avatar
no, you dont but i was thinking you would check the valve seals
either way...you'll be fine and it's up to you what you want to do first
aen is offline
Old 08-19-2008, 04:53 PM
  #225
ahhh i see. yeah that is something i wanna do. there a sealing procedure on the valve cover?
Old 08-19-2008, 04:58 PM
  #226
aen
aen's Avatar
nope, the thing just goes back on. whne you do it gimme a call and i'll help you real quick.
aen is offline
Old 08-19-2008, 10:31 PM
  #227
i swapped out the pcv valve. ill let you be the judge of its condition. i think it could be normal though...
Old 08-19-2008, 11:30 PM
  #228
well, i was gonna open up the valve cover but i gotta get to doing some things today finally... i may do it tonight! we'll see. thanks aen :D
Old 08-24-2008, 06:57 AM
  #229
just redid my oil pan today. gonna let it cure for a good 24h. also.... this supercharger is leaking oil. this time its visible from the outside. looks like s/c #3?
Old 08-24-2008, 04:10 PM
  #230
Mr_Meaty's Avatar
that's crazy...sorry I couldn't find my old sealand for you.
where exactly does the SC leak from?
Mr_Meaty is offline
Old 08-24-2008, 04:44 PM
  #231
its all good we still had the stuff we had from last time. only thing we had an issue with was removing the oil pan. so my friend had this great idea of taking a breaker bar from the top of the engine bay (end wrapped in cloth to prevent damage) and pushing down on the edge of the pan. worked great!
anyway...
Old 08-24-2008, 09:22 PM
  #232
aen
aen's Avatar
next time you want to take off the oil pan use razor blades and slip them into the silicone and hammer them all around, they fall into the oil pan and slices the silicone sealant in half
aen is offline
Old 08-24-2008, 09:24 PM
  #233
ahh yeah. we used razorblades to remove the sealant after it was off though...
just drove it around parked it. let it run. checked for leaks. nothin :D sweeet. gonna put some degreaser ont he underside to pretty it up
Old 08-24-2008, 09:31 PM
  #234
aen
aen's Avatar
if it makes you feel better, i blew my engine up.
spun the rod bearings. somehting ahppened. i don't know.
aen is offline
Old 08-24-2008, 09:52 PM
  #235
omg.
so just drivin and BAM done?
Old 08-24-2008, 11:22 PM
  #236
crush02342002's Avatar
sorry to hear aen, have you torn the block down yet?
crush02342002 is offline
Old 08-25-2008, 05:32 AM
  #237
missReni's Avatar
omg Hieu... Do you know what happened to it yet?
@Ardie: Is your s/c still leaking in that one spot you marked in a picture that isn't yours?
missReni is offline
Old 08-25-2008, 06:31 AM
  #238
still? of course? haha its just a really really slow leak.
Old 08-25-2008, 09:36 PM
  #239
Mr_Meaty's Avatar
what the crap, heiu? was that in vegas or in az? How do you know?
Mr_Meaty is offline
Old 08-26-2008, 01:49 AM
  #240
and wouldnt ya know it... dezod posts 2 threads selling a motor...
https://www.scionlife.com/forums/viewtopic.php?t=234775
https://www.scionlife.com/forums/viewtopic.php?t=234774
DaBlackBox
134
04-10-2022 02:04 PM
mischadoll
03-09-2015 05:48 AM
DougC
02-22-2015 02:39 PM
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
Quick Reply: supercharger issues... oil leak and burn, running rich...
