Supercharger / Oil Catch Can Set-up
#41
Originally Posted by hunterUnknown
hate to resurrect a thread but i need to install a catch can as well.
my cat just died. (that sounds sad)
but yeah, its getting replaced now. and a quart of oil magically disappeared. ive only been s/c for about a month. 3000 miles-ish.
helpful info guys!
helpful info guys!
Leave the cat out. Dont replace it. Get a catch can! I mounted mine on the side of my battery. If you look in my gallery you can see it.
#43
helpful info guys!
helpful info guys!
i would love to get a header and call it a day with the cat, but im really low on money these days and its warranty work so... i have to get it done :\
i am certainly going to get a catch can though. i'll be checking out your gallery in a sec
#44
cats seem to be dying on tc's left and right...especially after s/c.
dual catch can installed stealth...
http://blog.scionxtc.com/blogs/archi...catch-can.aspx
#46
nice! ill be doing that for sure.
so you just check this can every once in a while and make sure it isnt full?
EDIT: looking at the site you provided on your writeup, i just pick up a stage 1 dc3, no options, correct?
#47
i just did the installation and it went... good and bad. bad because it didnt work until i undid some of the work. the piping in the walkthrough was too small for the new specifications of the dc3, but thats my fault for not checking ahead of time.
anyway other than that, we'll see how it works!
#49
#50
Originally Posted by BLUEMEANIE
I ended up ordering my DC3 with custom properly sized NPT threaded 90deg brass barbs rather than the standard fully welded nipples.
#53
^ You can run a catch can or two on an n/a, turbo or sc car with the same benefits.
Saikou Michi Co.
http://saikoumichi.com/product_line.html
If you get the DC3 dual can, custom order it with 3/8" (pcv) and 5/8" (breather) barbed brass 90deg elbow fittings. Mention my name (Eric) and that it's for a supercharged Scion tC when you order it and he'll know what you're looking for.
If you get a single can just for the breather get 5/8ths brass barbs or the standard 5/8ths welded nipples
...and this is why the Saikou Michi Co. catch cans are better than the other brands...
http://saikoumichi.com/OCC_explanation.htm
Actual car nipple dimensions: (thanks jetlounge)
- pcv out from mani is 3/8"
- pcv in to intake is 1/2"
- breather in/out is 5/8"
Originally Posted by Ace83
im looking for a catch can, what you guys recommend?
#55
#59
Right on.
You could go with the Split DC3 and the custom barbs. Might be a little easier to fit them. Each can is not that much bigger than a soda can.
http://saikoumichi.com/SPLIT_DC3_page.htm
#60
it wasnt a bad install. just make sure you have the right size tubes. do it, its worth the peace of mind.
only thing im not going to like is disconnecting it and cleaning it out every 6 months. i dont even know how/with what.
