Swithcing from the S/C?
Old 03-06-2007, 01:20 AM
jwaggz82's Avatar
Originally Posted by 1tc4u2nv
Originally Posted by jwaggz82
^ya - i think they got 15-20whp with it. But the methanol isn't just power ....its cooling also. Overall its the best solution for a tuned s/c setup because adding extra pipe for the IC didn't turn out that well for a few guys.
methanol is a good idea but i would prefer vortech to come out with a power cooler i think bcnu 702 said that he was working with vortech to create one i wonder if he has any updates
what post is that from?
jwaggz82 is offline
Old 03-06-2007, 02:07 AM
1tc4u2nv's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=163806 but it was locked
1tc4u2nv is offline
1tc4u2nv's Avatar
1tc4u2nv is offline
Old 03-06-2007, 03:20 AM
jwaggz82's Avatar
^ yea - locked for no reason.
jwaggz82 is offline
Old 03-06-2007, 04:58 AM
TRDPower's Avatar
I have just about every mod to have at this satge. NST pulley 9.5 pulley, Ingalls dampner, Dc header, megan s pipe, custom 2.5 inch cat back with magnaflow high flow cat, bosch 110 bpv, short shifter. And Probably more I have forgotten. Stock tires atm, I wanna run a 14 psi pulley and tune with either the dezod "stand alone ems" or the aem fuel ignition controller (neither of which I think are ever going to come out. And run the Water meth and injectors. I'm not worried about the warranty anymore, i destroyed the header heat sheild installing the header. So thats not a factor. I'm looking for in the 300hp neighborhood. And yes, I got the water meth to help with the insane heat soak. I wish the S/C was intercooled.
TRDPower is offline
Old 03-06-2007, 01:30 PM
jwaggz82's Avatar
I dont know how safe 14lbs is because almost nobody is boosting that high but that combo will put you around the 300whp mark.
jwaggz82 is offline
Old 03-06-2007, 01:32 PM
Robs_tc's Avatar
14psi is still 14psi, that's a lot of boost on a stock engine even if it's only for a few hundred rpms.
Robs_tc is offline
Old 03-06-2007, 08:18 PM
jwaggz82's Avatar
I want to add to what I put because it might sound misleading - 14lbs is not safe on stock internals. ....but with your mods and that boost you should be around 300whp. Karl had 320whp on 12lbs but that was with cams also.
jwaggz82 is offline
Old 03-06-2007, 08:23 PM
Robs_tc's Avatar
Water/Meth is just as important.
Robs_tc is offline
k1114
43
03-01-2023 03:08 AM
ColonelSanders85
12-09-2020 09:44 AM
Greg S
07-21-2016 07:28 PM
Kanchi
06-29-2015 02:42 AM
rshissler
03-24-2015 10:46 PM
Quick Reply: Swithcing from the S/C?
